Author Topic: SSA3015X Plus remote file access  (Read 1545 times)
Offline RossTopic starter
« on: March 02, 2023, 04:40:24 am »
Hi Everyone,
I am probably missing something very obvious, but for the life of me I can't seem to work out how to get access to the Siglent Spectrum anayliser file system. I would like to get the test results and spectrum save on the unit. I have had a look at the manual and the web doesn't help.
Anyone know how to do this,
Thanks,
Ross
Re: SSA3015X Plus remote file access
« Reply #1 on: March 02, 2023, 06:13:01 am »
Hi Everyone,
Thanks,
Ross
Press File to enter the File Manager UI.
Then select View All to see all files saved in the Local file system.
Select/highlight files of interest and press Copy then select your USB stick and Paste the file to USB.
Rinse and repeat.
Tips
Here I use a USB hub to allow for a mouse and USB stick connected into the one USB port these are equipped with.
Avid Rabid Hobbyist
« Reply #2 on: March 02, 2023, 08:55:22 pm »
Thanks for your response, so there is no way to get the files over LAN or USB host?
Thanks,
Ross
Offline hendorog
« Reply #3 on: March 03, 2023, 12:31:27 am »
Hi Ross,
You should be able to access it via FTP.
Sorry not around an instrument for a while but hopefully that will help you figure it out.
The following users thanked this post: Ross
« Reply #4 on: March 06, 2023, 01:59:24 am »
Hi Ross,
Thanks that is exactly what I am looking for, surprised it is not mentioned in the manual, perhaps I was looking at the wrong one.
