Products => Test Equipment => Topic started by: NiaDebesis on June 16, 2017, 06:51:10 pm
Title: Strange bootup rigol 1022u
Post by: NiaDebesis on June 16, 2017, 06:51:10 pm
Hello
I have taked a rigol 1022u and it arribed with the handle broked..all seems to works correctly, but when I power on the item it show some vertical and orizzontal strips, and when it power on completely the strips disappear, but if I look with attenction at the screen I can see these strips, is a shade, no burned pixel
Title: Re: Strange bootup rigol 1022u
Post by: colorado.rob on June 16, 2017, 07:15:19 pm
I would guess that there is a problem with a ribbon cable connecting the display to the control board.  Does it look like it has been disassembled before?  Post a picture if you can.
Post by: mcinque on June 16, 2017, 07:46:13 pm
It's normal, all that units have that lines, it's because they power the display before initializing the controller.
Me too thought was a defect.
https://www.eevblog.com/forum/testgear/rigol-dg1022-bad-lcd-engineered-owners-leave-your-hopinion/msg269550/#msg269550 (https://www.eevblog.com/forum/testgear/rigol-dg1022-bad-lcd-engineered-owners-leave-your-hopinion/msg269550/#msg269550)
Edit: also, the lcd used for the 1022 is a bit crappy and you'll see strange lines also with high luminosity settings. You should deal with it.
