Author Topic: TDS3014B upgraded to 600MHz  (Read 1067 times)
Offline ShivTopic starter
« on: November 11, 2020, 09:37:59 am »
Hi all, sorry but, for now that´s only a clickbait to ask.
I have a TDS on sight, but it have encoder problems... (works ok, but there are repaired and could fail again)
The price for the TDS is good, but it isn´t for the replacement board (to make it new)
I have oscilloscopes at work so I don´t need more than 100-200 MHz at home.
The question is...
What would you pay for something like that?
It´s for calculate how much I can spend on it.
The instrument is in good condition and I will upgrade it to 3064B, add tek probes (TPP0200 and P6139A) and run a full 600MHz calibration/adjustment at work (Metrology center, it could be traceable certified)
If somebody is interested, please tell me what will you spend for that.
Seeing ebay I´m thinking about 800-1000 as it is or go up with a brand new board. (350-450 bucks)
Offline eplpwr
  • Junior VoltNut
Re: TDS3014B upgraded to 600MHz
« Reply #1 on: November 11, 2020, 06:24:57 pm »
US$ 20-30 would be sufficient for a quality encoder.
Thanks for the clickbait, NOT.
« Reply #2 on: November 12, 2020, 08:09:38 am »
Thanks for the answer, but NOT.
These aren´t normal encoders mounted ONboard, these are INboard
https://www.eevblog.com/forum/repair/tds3000b-tds3054b-strange-type-rotary-encoder-repairreplacement/
