Author Topic: TC1 lcr-meter transistor-tester fix  (Read 204821 times)
Offline iv3wjr
Re: TC1 lcr-meter transistor-tester fix
« Reply #300 on: December 29, 2023, 03:04:02 pm »
Sorry, forgot to add the battery voltage: 4.16V at the battery pins,  after full charge (green led) and charger disconnected. Charging or not makes no difference, cannot get  rid of the message after power on/off several times.
Offline njsw88
« Reply #301 on: February 02, 2024, 02:41:23 pm »
i know this is an old post but i have the same issue with my TC-1 multi-function tester, but my pcb board, is very different than the one in the post, i have attached the pic but i found that C11 and C12 seam to be ok, but i found that there is a short on C2 , is this a new fault or should i still replace the C11 , C12 and the C2, and what should i replace them with as i do not know what they are ? please help as im new to electronic any help at all will be appreciated, thankyou shane from Brisbane Queensland Australia
Offline madires
  • A qualified hobbyist ;)
« Reply #302 on: February 02, 2024, 05:19:33 pm »
Remove C2 and check if it's really shorted or if the short is somewhere else. BTW, your tester has a fake ATmega (looks like an APT32F172K8T6).
The following users thanked this post: njsw88
Offline njsw88
« Reply #303 on: February 04, 2024, 06:41:41 am »
tock out the C2 and no difference still short some where
Offline njsw88
« Reply #304 on: February 04, 2024, 07:17:05 am »
hi again , what is a good multi-function tester to buy i was looking at the " MESR-100 ESR Capacitance Ohm Meter Capacitance Resistance Tester" or is there a better on with the same sort of display as the TC1
thankyou in advance for your replies shane
Offline MarkMLl
« Reply #305 on: February 04, 2024, 09:05:41 am »
EEVBlog still advertises budget multimeters: perhaps we also need a definitive recommendation for a budget component tester with a stable design that the community can support happily.
MarkMLl
Offline madires
« Reply #306 on: February 04, 2024, 09:28:03 am »
AY-AT (aka GM328A) with a DIP ATmega (best bet at the moment to avoid alternative MCUs).
Offline njsw88
« Reply #307 on: February 04, 2024, 10:48:29 am »
yes that would be awesome
Offline njsw88
« Reply #308 on: February 04, 2024, 10:49:55 am »
yes i will thanks
Offline MarkMLl
« Reply #309 on: February 06, 2024, 10:07:18 am »
But from where? Is there somebody reputable like Farnell ** who will commit to supplying a stable design?
** Noting of course their extortionate small-order handling charge
MarkMLl
Offline njsw88
« Reply #310 on: February 07, 2024, 03:12:28 am »
what about RS Components
Offline njsw88
« Reply #311 on: February 07, 2024, 10:06:14 am »
what i have found now , that if i put 3v on the VCC of the CH340N chip which is located at U3 on my PCB board which i show on my other post it starts up and i have no more shorts on C2, do you think that this is the problem ?
Offline madires
« Reply #312 on: February 07, 2024, 11:08:09 am »
How much current is drawn on that external 3V? Are CH340N and C2 connected via some trace?
Offline njsw88
« Reply #313 on: February 08, 2024, 09:17:17 am »
3v 1amp
Offline madires
« Reply #314 on: February 08, 2024, 09:39:41 am »
Such a high current is an indication of a shorted component. You could use that and look for a hot component (most likely an MLCC).
Offline njsw88
« Reply #315 on: February 08, 2024, 02:12:45 pm »
ok thankyou i will check
Offline MarkMLl
« Reply #316 on: February 09, 2024, 09:53:49 am »
They unilaterally cancelled half of one of my orders after assuring me on the 'phone that they were able to fill it. 'Nuff said? :-/
MarkMLl
Offline njsw88
« Reply #317 on: February 09, 2024, 01:11:45 pm »
hi again guys ok the Volts are 3.2v and the amps are 0.3 on the U3 CH340N chip it cam on and stayed on, but i notice that the MEGA928P got hot but could not feel any other chips getting hot, any ideas ? or is it the MEGA928P chip that needs replacing, thanks Shane
« Last Edit: February 09, 2024, 01:14:32 pm by njsw88 »
Offline madires
« Reply #318 on: February 09, 2024, 03:03:29 pm »
Another common problem is a bad SRV05-4 (U6 in your case, near the ZIF). If it's shorted it would also impact the MCU. Remove U6 and see if it helps.
Offline njsw88
« Reply #319 on: February 10, 2024, 04:42:55 am »
ok thankyou i will give it a go thanks again
Offline spacebiscuit
« Reply #320 on: February 21, 2024, 06:29:20 pm »
Can I jump in - I have the T7 - was working fine but I think I forgot to discharge a capacitor. Tried to turn on the tester today and it is dead - led comes on if I plugin the usb.
I've open it up and I get open circuit on c3, c25, c9 and r15 - is that my issue?
I have this model (taken from page 11)
Thanks in advance.
Offline carl1961
« Reply #321 on: February 22, 2024, 03:21:08 am »
Thanks in advance.
as on page 11   looks like same as one  @madires   said has a LGT8F328 MCU  I have the same board, but still working, I never tried dumping the firmware, most likely useless to try as they seem to lock them from dumping.
« Reply #322 on: February 26, 2024, 08:43:36 pm »
So is this only good for the recycling/trash now?
Offline njsw88
« Reply #323 on: March 02, 2024, 02:41:08 pm »
Can any one tell me what this chip is or what is its equivariant, as i cant find anything on the net about this chip.
any help thankyou
Offline indman
  • Country: by
« Reply #324 on: March 02, 2024, 04:45:22 pm »
njsw88, this is a microcircuit SD6210A
