Hi, does somebody already had on a TC1 (M-tester V2.12k) a Zener value displayed always (with no component connected) at the startup?. All other functions look to be ok, if I put other kind of component , it is ok, but with no component it detect a zener and with a zener the measure is bad.
I checked 37v (approx) is here, the zener voltage is going to PA4 thru a divider by 10, Should have 3,7v here but input look to be pulled down by PA4 and the low voltage is displayed like a zener voltage. Also the Ref voltage 2.5V (TL431) is also pulled down to 0V on PA3 by the 324PA, if I isolate PA3 the ref voltage rise up to 2,5V. If I isolate the PA4 , it also diplay a zener voltage at startup with 0V value !
I do not tremember having done a bad measure with non discharged component , TC1 did it by itself one day at the bootup.
Before trying to change the ATMEGA with a new one and flash it with the original TC1 firmware provided on this thread, maybe I missed something more easy to fix this TC1?
Any advice or clue will be apreciated.
If I start in this way , I will probaly tweak it with alternative k firmware and hardware U4 mod later (but before I would like to fix it ) ...
