Author Topic: Thinking of buying a scope, how is the SDS1052DL for a beginner?  (Read 15920 times)
Offline Red SquirrelTopic starter
« on: December 13, 2014, 10:47:19 pm »
I did a quick search and I did not find much but from what I found it's decent I think... but before I pull the trigger just figured I'd ask what people think of the Siglent SDS1052DL?  It's on sale right now for $300 and regular price is $144 so it's very tempting:
http://www.amazon.ca/Siglent-SDS1052DL-Oscilloscope-Channels-100-240V/dp/B00GQNN70A/ref=sr_1_1?ie=UTF8&qid=1418509079&sr=8-1&keywords=oscilloscope
Any feedback would be appreciated, thanks.
Offline MartyD
Re: Thinking of buying a scope, how is the SDS1052DL for a beginner?
« Reply #1 on: December 13, 2014, 10:56:42 pm »
TBH, for just $40 more go get the SDS1072CML as it gives you twice the sample rate, much more sample memory and also a higher bandwidth (70MHz vs 50MHz).
http://www.amazon.ca/Siglent-SDS1072CML-Oscilloscope-Channels-100-240V/dp/B00GQNNHJG/ref=pd_cp_hi_0/177-2495856-3807862
To me, this sounds like the better deal.
Marty
Offline pickle9000
« Reply #2 on: December 13, 2014, 11:04:15 pm »
Can you afford an extra 100 bucks?
DS1054Z oscilloscope
The scope is new, having some teething problems (it's new), so far hackable,
http://www.tequipment.net/Rigol/DS1054Z/Digital-Oscilloscopes/
eevblog discount
https://www.eevblog.com/forum/chat/special-price-for-eevblog-members/
« Reply #3 on: December 13, 2014, 11:11:49 pm »
Amazon.ca does not have that one.  Trying to stay on a budget and ordering without having to pay customs or high shipping.  Though 40 bucks extra to bump to 70mhz might be worthwhile though so I am now considering the SDS1072CML here: http://www.amazon.ca/Siglent-SDS1072CML-Oscilloscope-Channels-100-240V/dp/B00IP5III8/ref=sr_1_2?s=hi&ie=UTF8&qid=1418512269&sr=1-2&keywords=SDS1072CML.
Offline MartyD
« Reply #4 on: December 13, 2014, 11:18:23 pm »
Erm.. may I ask why you choose the same model for $434 instead of the one with free shipping from my link for $345? ;)
« Reply #5 on: December 13, 2014, 11:44:42 pm »
Oh I missed that, the second time I just searched for the model number. Yeah I got the right link now.
http://www.amazon.ca/Siglent-SDS1072CML-Oscilloscope-Channels-100-240V/dp/B00GQNNHJG/ref=sr_1_1?s=hi&ie=UTF8&qid=1418514216&sr=1-1&keywords=SDS1072CML
« Reply #6 on: December 14, 2014, 03:56:10 pm »
Well I pulled the trigger (no pun intended).  I really need to stop spending money like this lately as I've been trying to build an emergency fund but,I've always wanted a scope and I could not pass up this deal.  Got the 70khz model with free shipping.  Should get it a bit after Christmas, can't wait to play with this new toy.   I'll have to watch more videos on how to use them, I have watched some already and know the basics though.
Offline MartyD
« Reply #7 on: December 14, 2014, 04:51:27 pm »
Me too, I sinked around €3k last weeks in test gear for my home "lab"... ::)
However, everybody needs a scope and I think this CML series from Siglent is a affordable, solid, no-nonsense beginners scope. I added a SDS1102CML to my setup 2 months ago just because it was cheap (and I was curious) and I'm pretty happy with it, tho I much prefer my old Tektronix CRO's for most of my work.
I can highly recommend watching w2aew's videos on scopes, you'll learn alot from them: https://www.youtube.com/channel/UCiqd3GLTluk2s_IBt7p_LjA?&channel=w2aew
Have fun!
Marty
Offline tautech
« Reply #8 on: December 14, 2014, 09:07:13 pm »
You probably mean the 70 MHz model, I guess SDS1072CML?
Good little DSO, firmware mature and straight forward to use.
I like the Siglent range for their 400 V Ch input capability, much less likely to overload inputs with a high voltage applied.
It will take a while to find and exploit the features available  especially for a beginner.
Do some study, read the f******g manual (RTFM) and ask questions, there are many here that will help.
Good choice.
I know it will serve you well.
« Last Edit: December 14, 2014, 09:48:32 pm by tautech »
Offline timb
    • timb.us
« Reply #9 on: December 14, 2014, 09:55:55 pm »
Who said anything about mains voltages?
Sent from my Smartphone
Offline tautech
« Reply #10 on: December 14, 2014, 09:59:25 pm »
Uuuh! Beginners should not probe around mains voltage without knowing what they're doing, it likely not only harms the scope but also the user! :-BROKE
Sure, but was is my reasoning for selecting Siglent products.
Post edited
Delete yours if you wish for a tidy up of the thread.
« Reply #11 on: December 14, 2014, 11:11:36 pm »
Actually was going to ask about mains, can you actually stick it in mains or do you need to do anything special?  Obviously you'd want to either not use the ground clip, or ensure that the ground source you use is the same as the scope's ground.  Or isolate the scope and plug into a GFCI, but probably best not to isolate it.  Would be neat to test out UPSes and such to see what kind of output they produce. Some UPSes do funky things with the grounding so would just want to watch with that.
Though everything I read about using it for mains seems to suggest it will somehow take my arm off or blow up my house like it produces a 500kv arc flash or something.  Anything special I need to know that makes it so dangerous with mains compared to a multi meter or other situation dealing with mains?
Offline tautech
« Reply #12 on: December 14, 2014, 11:24:34 pm »
Presuming you will use safe probing techniques, get a 100:1 probe for additional safety for high energy circuits.
Learn and understand probe "Voltage De-rating with frequency".
Offline tom66
« Reply #13 on: December 14, 2014, 11:35:42 pm »
You really shouldn't. The oscilloscope is rated  CAT I, which generally speaking means its input cannot be directly connected to the mains, as the input is not rated to handle over-voltage transients typically expected on such a circuit.
You can use a CAT II minimum rated 10X probe (600V or higher), or an isolating step-down transformer with sufficient series resistance to measure the mains with an oscilloscope. (Not that it's much use - it's just a sine wave with some rather flat-tops caused by all the low PF simple full-wave rectified supplies...)
You -should- be able to probe an isolated UPS output with a 10X probe, as long as it is operating on its internal batteries only.
In general, you don't want to go about floating your scope. The reason being you lose a large part of the protection that a grounded scope offers you. If you float your scope, everything ground on it can be potentially live. With a good scope, if you happen to connect the ground to a live high-ish energy source, the worst damage you'll usually do is blow up a probe clip and/or trip a breaker.  Maybe the scope could be damaged, but this is rare because the shielding of most oscilloscopes, and the BNC connector, offers a low impedance to ground, bypassing sensitive input circuits. But, if you remove this grounding, you can touch any metal part of the scope and it could be live, without you knowing.
« Last Edit: December 14, 2014, 11:39:06 pm by tom66 »
« Reply #14 on: December 17, 2014, 10:55:36 pm »
It came in!  Was not expecting it so soon, Amazon orders usually take a while. I've had some take 2 months.
Just messing around with it using a wall adapter and bridge rectifier. I have lot of reading up to do so I can learn more advanced features like recording a time sequence of data such as a capacitor discharging over a period of time.  That's possible to do right?  Like I can tell it to record for nn time and it will capture data?   Do like the screenshot feature too:
