I see that the recommended/official wifi adapter for the Siglent SDS1104X-E is the TP-Link TL_WN725N, but I'm wondering if a TL-WN722N could be used instead?
I currently have this adapter already and use it for other projects, and it'd be great if I could use it with the scope vs. buying a TL_WN725N. I know it's not terribly expensive and can be had for cheap, but ideally I'd prefer cutting down on devices, if possible.
My thought is that given they're so close in model, it could work, but I'm not sure if the scope has a singular predefined "driver" that will only work with the 725N or its specific chipset. If there was a way to mod the scope to change out its wifi adapter compatibility/driver, I would happily attempt that, if possible.
