Perhaps in future you want upgrade your scope for get more features with TDS3ENG module, you only need tds3fft or tds3trg modules, even with 24C02 eeprom soldered to SIM card socket you can put in lateral slot of your scope.
If you using CH341 programmer with tds3fft or trg only need put 4 wires, Vcc, SDA, SCL and short to ground A0 and A1 more gnd of stick, you can programing without open the stick module. I attach my bin file for this. You must change txt extention to bin.
