Author Topic: Teardown, Repair & Analysis of a Rohde & Schwarz FSH3 3.0GHz Spectrum Analyzer  (Read 21851 times)
Online HugoneusTopic starter
    • The Signal Path Video Blog
In this episode Shahriar examines a faulty R&S FSH3 100kHz – 3.0GHz Portable Spectrum Analyzer. This exceptionally dirty unit does not power on and is missing a power supply and battery. After verifying the correct operation of the battery charger circuit and keypad the problem is traces to a damaged SOT-23-6 MOSFET device which is part of a fly-back DC-DC converter. A replacement MOSFET with a lower current rating proves to be a failure as the device fails on startup. A higher rated MOSFET resolves the problem and device begins to operate correctly.
The block diagram of the system as well as a detailed block diagram of the RF section is presented and correlated with the teardown of the RF section. The super-heterodyne down-conversion circuits and components are examined.
Watch the video here: [51 Minutes]
youtu.be/qD05ZFVplE0
More videos at The Signal Path:
http://www.TheSignalPath.com
« Last Edit: August 04, 2015, 02:02:02 pm by Hugoneus »
The following users thanked this post: EPTech, pdenisowski, tonyM
Offline dr.diesel
I'd be tempted to fab a custom metal bench enclosure.
Excellent video as always.
Offline ElectroIrradiator
  • More analog than digital.
Ah, you posted the video in here. Your first replacement MOSFET blew up because it was a P channel device. :D
I noticed that I actually showed the wrong datasheet I think. I believe that the part that I used was a N-channel, but rated only to 400mA and not 1Amp as the PMOS datasheet indicated. :)
Offline tec5c
Another great video Shahriar. It's always the highlight of my day/week/month when a new video is posted up on the signal path.
Keep up the good work. (insert thumbs up emoticon as Windows 10/Microsoft Edge doesn't seem like it's capable!)
Offline PA0PBZ
I'm most puzzled by the word "naamplaat" on the keyboard foil, which I can find no other meaning for than the Dutch word for nameplate...
A great video as always, interesting to see the noise generator just before the ADC in the block diagram, I guess that is an attempt to dither the signal.
Offline Wuerstchenhund
  • Able to drop by occasionally only
Great video, as always!  :-+
The MOSFET problem seems to be a regular issue with the FSH3, which btw was the first generation of handheld SAs from R&S. The FSH Series is still made, however from what I know the hardware for the old FSH3 and the newer FSH4 and above is different (the FSH3 was known for being pretty slow and having occasional stability issues, the bigger/newer models are supposed to be improved).
Offline dadler
Which Mosfet did you end up using in the end?
I ended up using a SI3454.
Offline German_EE
I know that I have asked this before,  but is there any chance you could do a short video on some of the weird PCB-based structures that we see on microwave PCBs? There are comb like areas, others shaped like fantails and lengths of PCB that seem to do nothing but I'm sure have a purpose in life.
My knowledge stops at 500 MHz or so and even then I'm struggling so a little help with the 'RF Voodoo' would be appreciated by your viewers.
Warren Buffett
Offline Melt-O-Tronic
  • Brilliant with a slaughtering iron in my hand!
Another brilliant video!  I am learning so much, thanks to you and W2AEW.  Lately, nothing makes me happier than a new video from either of you guys, so your increased rate of production lately is profoundly appreciated.    :-+
To tag on to German_EE's post, I'm particularly curious as to WHY distributed element circuits do what they do.  Since I read Walter Maxwell's explanation of transmission line reflections in his book, "Reflections III", the light clicked on and I'm finally beginning to understand RF (and that's why you and W2AEW are so important to me now).  So I think understanding the "mechanics" (physics) of distributed elements is another opportunity for revelation.
Also, please give Pooch my regards, plus an extra scratch behind the ear.   ^-^
Offline RRobot
The Wikipedia article is a good starting point:
https://en.wikipedia.org/wiki/Distributed_element_filter
Offline AndreasF
    • mind-dump.net
 :-+  Excellent video!
I loved your expression of joy/surprise when it powered on for the first time (probably because you didn't expect it to turn on).
my random ramblings mind-dump.net
Thank you all. I do want to make more tutorial videos but I do have some important reviews which I need to complete. There is also typically a lot of tutorial style material in my reviews which I hope would be useful.
Will do! :)
Offline Dubbie
Everything you post a new video I get a big groan from my wife because I like to watch it on the TV in the living room. It's funny though, for some of the repairs she even exclaims "yay" when the thing turns on for the first time. Don't stop making videos. I learn a lot from them.
Thanks! This one had a yay moment from myself. :)
Offline G0HZU
Sorry to be a neghead but... I wasn't very impressed with the signal path walkthrough parts of this video... :(
I skimmed over the repair bit to get to the part I was most interested in which was the block diagram and internal view of the RF PCB. I didn't think this was presented that well because there were lots of incorrect things said. I guess none of this really matters but the PCB walkthrough was especially poor because Shahriar got the description/location/roles of the various mixers and filters mixed up.
I can glance at that PCB and see the correct signal path very easily including the unused sections for the 6GHz version on the other side of the PCB.
A couple of other things to note. At 46:36 the loop BW of the PLL will be chosen at 30kHz mainly for phase noise but also for the tuning/startup/lock speed of the PLL.
At 46:40 the 'VCO 3X' doesn't refer to a frequency tripler or overtone. To put a tripler here would not be a good idea... 'VCO 3X' refers to a bank of 3 discrete VCOs that get selected as required to cover the total 4-7GHz range of the first LO. It looks like they used printed resonator designs. They use three VCOs here because it gives the best phase noise performance compared to trying to do this with a single VCO. This is a fairly common approach. Also the design is technically easier/safer than trying to cover this range with a single VCO. The downside is the added circuit size/complexity and the associated management and startup/locktime issues as it sweeps the full range in these three chunks. It's easy to spot these three discrete VCOs in the PCB layout as they take up a lot of space. eg see the image below where they are arrowed/circled in blue.
« Last Edit: August 08, 2015, 03:14:38 pm by G0HZU »
The following users thanked this post: tonyM
Offline G0HZU
Dunno if this helps but here's a crudely marked up image showing the location of the filters and mixers in the basic RF path for the 3GHz range.
Obviously, I don't work for R&S and this is the first time I've seen inside one of these but I think my marked up image below shows the locations/descriptions better.
« Last Edit: August 09, 2015, 02:03:02 pm by G0HZU »
Offline G0HZU
I can also describe the signal path for the 6 GHz option if anyone wants to see it?
Offline rs20
Thanks for the picture with all the different blocks overlaid -- it's nice to make observations like seeing the DC connection on the LPFs, and the lack of a galvanic connection for the BPFs (as you would expect), and the 3GHz LPF having features roughly double the size of the 6GHz LPF, etc etc. It's nice to feel like one has a clue what's going on!
I'm always happy to see more microwave magic with schematic overlays!
G0HZU,
Thanks for the analysis. As I pointed out on the video overlay, this was a very quick overview of the board. I spent less than 30 second looking over it as I was in a rush to close it up. A thorough overview of the board was not the intention of this video.
Making YouTube videos is not my full time job, time is a major constraint. When I do a full video on microwave design I'll make sure to go through everything in detail.
By the way if you are interested in seeing VCO's with 2nd harmonic or tripplers I have built a few all the way up to 160GHz. In fact, banks of VCO's with/without multipliers to cover nearly 50GHz of tuning range.
« Last Edit: August 10, 2015, 02:04:06 am by Hugoneus »
Offline G0HZU
I guess it's easier for someone like me to instantly spot these issues as I have many years' experience designing converters using filters just like these and in similar frequency bands and for similar applications. But I'm still very surprised that despite 6000 views on youtube nobody else pointed out that the PCB walkthrough got the various mixers and filters mixed up. These are classic elliptic LPF and interdigital BPFs. I think the 831MHz IF2 filters will be Murata SAW filters rather than cavity filters.
I think quite a few people would be interested in seeing info about oscillator design up at those frequencies :)
However, I don't think it would be a good idea to use a VCO + tripler to generate 4 to 7GHz for the first LO on this type of analyser as it would demand so much more PCB space for the required filtering and also it would generate a lot more internal spurious issues and also the close in phase noise of the synthesiser would be higher with a tripler approach.
I agree. I am an ASIC designer myself and a quick glance at a layout gives me a lot of information.
I also agree that a trippler is not a good idea on this board (and was surprised myself when I thought it was implemented). The mm-wave and THz oscillators have to use multipliers as it is not possible to reliably make fundamental VCOs at those frequencies with devices which have fT/fMAX <300GHz.
PS: I am shooting a VNA repair which I think you will like. ;)
VNA repair . . .
Getting a better understanding of how VNA's function is exactly what I've been wanting to learn.  Can't wait.  Feel free to make a 12+ hour video with plenty of detail if you want.   :D
