Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
HP 8752C A3 source parts identification help needed
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HP 8752C A3 source parts identification help needed (Read 2042 times)
WuLi
Newbie
on:
April 24, 2014, 12:09:05 pm »
Hi all,
I'm in the proces of debugging the signal source of my vna and I need some help on identifying two zener diodes. The diodes have the following codes on them:
1) 106 25K 507
2) 685 35K 451
I was able to retrieve the zener voltage of the first diode because there are more of them on the same board. It's a 22V zener. I'm unable to retrieve the value of the second one. There seems to be no logic in the coding. Can anybody help me out? I've attached a picture the two diodes are the ones with the black marker dots on them.
Logged
Thomas
Regular Contributor
Country:
Re: HP 8752C A3 source parts identification help needed
Reply #1 on:
April 24, 2014, 01:00:07 pm »
They are not diodes, they are tantalum capacitors. The band is on the positive terminal.
1) 106 = 10 with 6 zeros behind = 10 000 000 pF = 10uF, 25V. K is the tolerance.
2) 685 = 68 with 5 zeros behind = 6 800 000 pF = 6.8uF, 35V.
Logged
Sailor
Regular Contributor
Reply #2 on:
April 24, 2014, 01:01:58 pm »
Are you sure they're diodes? They look like tantalum caps to me.
Logged
WuLi
Newbie
Reply #3 on:
April 24, 2014, 01:20:40 pm »
Wow guys, that was fast.. Thank you very much.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
