Author Topic: Tds744a Application Menu  (Read 1039 times)
Offline mlefeTopic starter
  • Country: ar
« on: December 26, 2017, 02:44:10 am »
Hi guys,
      I've just fixed a TDS744a and I'm getting to know it :)
      I'm curious about the application button that you can reach by using the SHIFT button (on the measure button).
      I search for the functionality in the manual but I couldn't find it.
      When I push it, no options are shown: is that correct? What am I missing?
Thanks!
Offline chronos42
Re: Tds744a Application Menu
« Reply #1 on: December 27, 2017, 11:03:49 am »
A look in the scope manual will answer your question.
Or use the HELP function of your scope.
Application is only usable with an external controller.
  • Country: ar
« Reply #2 on: December 27, 2017, 02:59:40 pm »
I did look at it but obviously was not a good one... sorry about that.
You're absolutely right as well about the help button, I guess not used to that either.
In any case, thank you for the answer :)
