Author Topic: Rigol Dg1000z and SiFi  (Read 3229 times)
Offline FreighternutTopic starter
« on: July 06, 2014, 12:35:15 am »
I would be interested to know if SiFi has overcome some the pulse limitations that the DG4000 series has I.E. excessive rise times on short pulses in a long pulse period as per this post:
 https://www.eevblog.com/forum/testgear/rigol-dg4000-arb-gen-as-pulse-generator/msg140689/#msg140689
From pulse specs in the datasheet the spec for rise time suggest that it may still have issues:
Rising/Falling Edge ?10 ns (limited by the current frequency setting and pulse width setting)
Can anybody comment on this?
Save the earth - Travel the world by Container Ship! Almost zero carbon foot print
Offline cyr
Re: Rigol Dg1000z and SiFi
« Reply #1 on: July 06, 2014, 07:39:09 am »
Below is the rising edge of a 10 us pulse, configured with 10ns rise time, at 1kHz and at 1Hz. Looks OK.
The third one however is at 100mHz, at the "fastest" setting allowed (90ns rise, 100 us width)). Not exactly "high fidelity"....
DG1032z
And the settings follow that pattern going to longer periods. At 1uHz, the shortest pulse is 10s and the rise time is 9 ms.
« Last Edit: July 06, 2014, 07:45:09 am by cyr »
« Reply #2 on: July 06, 2014, 09:03:20 am »
Thanks CYR!
Excellent information and it looks like the dg1000z would work for me. My requirement is for simulating relatively low frequency (narrow pulse, long period) inputs to  microcontrollers. I don't think that I have a need to go out  1uHZ if I do I will certainly need to add a schmitt trigger between the ARB and the micro input.
I have another question; can the two outputs be synchronized and phase adjusted. My requirement here is to simulate quadrature inputs.
Many thanks again for your excellent reply.
Offline cyr
« Reply #3 on: July 06, 2014, 09:26:48 am »
You can adjust the phase for each channel and align them with a button press, and for most waveforms you can set the channels up to track in frequency (not in pulse mode for some reason, but square should work for quadrature).
Offline rodpp
« Reply #4 on: July 07, 2014, 03:29:27 am »
Does anyone knows where can I find technical details about the Rigol SiFi technology?
