Author Topic: Tek 7000-Series pushbuttons  (Read 1974 times)
Offline GianniTopic starter
« on: August 01, 2022, 05:52:52 pm »
Hi Guys,
I like to restore old Tek 7000-Series scopes. I ask you some suggestions related to pushbuttons.
I noted that the writing is very light and that almost any cleaner destroy them easily. Now I clean them with just water and a swab and then apply some transparent coating to protect them. I am considering creating water slides with a printer and then applying them. Has someone an experience in that?
Second question: how do you clean them? Deoxit? Isopropyl? Any other suggestion?
Thank you very much.
Offline Inside21
  • Country: ru
Re: Tek 7000-Series pushbuttons
« Reply #1 on: August 01, 2022, 07:44:48 pm »
I wash the instrument cases and front panels with hot water, a brush and soap  :-+
« Reply #2 on: August 01, 2022, 08:46:41 pm »
Hi Guys,
Welcome to the forum.
See here for nearly every trick under the sun for restoring instruments to their former glory.
https://www.eevblog.com/forum/repair/vintageclassic-renovation-techniques/
« Reply #3 on: August 01, 2022, 09:20:27 pm »
Wow! Fantastic, there is a mine!
THANKS!
Online David Hess
  • DavidH
« Reply #4 on: August 02, 2022, 07:39:32 am »
I clean the switch caps with dish soap and water.
The switches are the wiping type so *must* be lubricated after cleaning or the contact surfaces will destroy themselves.  I use MG Chemicals Super Contact Cleaner part number 801B which is a combined cleaner and lubricant.
« Reply #5 on: August 02, 2022, 09:52:51 am »
The old tek scopes have water slide transfers on the buttons. I learned that the hard way. I now just wipe around the edges of the buttons lightly.
As for cleaning switches I use WD40 contact cleaner (not normal WD40!!!!) and then exercise the switches. It’s like deoxit but cheaper and leaves no residue as well.
Offline Wrenches of Death
« Reply #6 on: August 02, 2022, 01:28:58 pm »
Don't forget the horizonal plug-ins!
I've still got a 7B92A around here some where that I wiped the marked push buttons spotlessly "clean" on. That was probably twenty five years ago. A definate "duh" kind of learning moment.
I can proudly say, it has only happened to me once!   :)
WoD
« Reply #7 on: August 02, 2022, 05:38:45 pm »
It happened to me last month and still whipping myself...
Nobody tried to print water decals with a laser printer? I found a similar font and I would like to try...
« Reply #8 on: August 02, 2022, 06:56:23 pm »
We had a discussion on here ages ago about that.  Never went anywhere though.
Online David Hess
  • DavidH
« Reply #9 on: August 02, 2022, 09:33:00 pm »
This question came up many years ago on the Tekscope email list and I believe they figured out what font Tektronix used.
« Reply #10 on: August 03, 2022, 06:40:28 am »
Any idea on how to find it out? I am not very used with this kind of things...
Online David Hess
  • DavidH
« Reply #11 on: August 04, 2022, 01:04:45 am »
I did a search and I think the font on the 7000 series push-buttons is "Univers Condensed", or the bold version of the same font.  There is some discussion here.
« Reply #12 on: August 04, 2022, 03:39:06 pm »
Thanks, very useful!
« Reply #13 on: October 15, 2022, 12:51:54 pm »
I succeeded restoring those old worn keys! You can read the all story, with detailed photos, in my free book on Tek scopes (at pages 216-219).
Here: http://www.k100.biz/parade.htm
« Last Edit: October 16, 2022, 01:28:22 am by Gianni »
The following users thanked this post: bd139, factory
