Hi, I would like to build a ATE test system for a small volume production line. The system would be used for measuring powers and doing a few functional test. I attached a general block diagram.
My question is what PC software platform would be good for this purpose. I am considering Python and sigrok. But would like other suggestions, pros and cons, etc.
Thank you
I did do ATE back in the 70's and 80's.
It is not so much the language - it is how you implement it.
Just some basic rules:
You need a language/ide that lets you single step, do breakpoints and repeat execution of the current line more than once.
Write the program so a 5 year old can follow it. ATE is really about keeping it simple.
Have a part of the program that is in the form:
Set the relays for test 1
Do test 1
Set the relays for test 2
Do test 2
That is what you want to be able to step through. If you need to do the same thing 5 times, it is great for stepping and debugging if you just repeat the test 5 times rather then using a loop.
Also, just as a few recommendations:
Make it as quick and easy as possible to swap jigs.
Avoid the need of vacuum holddown if possible, but if you end up with a mass of sprung test pins under the board, you will need it.
Make a second jig that allows you to test all relays easily - relays stick or degrade in ATE and you want to be able to test all the relay contacts in a minute or so.
Put something on each jig - like a resistor - so that the ATE can recognised the jig and automatically load the correct program. If you run the wrong program on the wrong jig, you can damage the DUT or the ATE equipment. We just had a standard routine at the start of each test that measured a jig resistor and turned it into a number (1k = "0", 1.2k = "2", ... ,8.2k ="11", 10K = 12, 100K = 24 based on the E12 resistor values - a simple logarithmic progression). Our test programs were actually just called "0", "1", "2", "11", "12", "24" and so the routine knew what program to call just from the resistor value. This eliminated the need for a globally accessible jig resistor value to program name lookup table.
Richard
