Hi there,
I recently acquired a Tek AWG-2021 from an EEVblog member. It works great
but I'm wondering if I should recap it. This is not a TE that will be used a lot so you can conclude that I'm a TEA member.
I opened it last week to see what was lurking inside and was surprised to see... nothing. Not a single one was leaking; they all looks as good as when they left the factory. I took multitude of pictures of all the boards for reference. Even the PSU looks great. I noted the specs of all the cap I found except for the CRT board so I can pre-order if I feel like it.
The only thing I noticed is the lithium battery that reads about 2.2V. That will be changed. What are the side effects of losing this battery? Loss of NVRAM?
In general, to prolong the life of these caps, should I turn it on often or not?
Thanks
Mario
