UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU romPost: MPC106 Walking-one passed. romPost: MPC106 configuration passed. romPost: First PCI access passed. romPost: PC87560 Walking-one passed. romPost: PC87560 configuration passed. romPost: DEC21554 configuration passed. romPost: PERFORMING ROM CHECKSUM TEST... romPost: ROM checksum passed. romPost: PERFORMING DRAM CELL TEST... romPost: Enabling data cache... romPost: Data cache enabled. romPost: Enabling instruction cache... romPost: Instruction cache enabled. romPost: DRAM Cell test passed. romPost: Disabling data Cache... romPost: Data cache disabled. romPost: Disabling instruction cache... romPost: Instruction cache disabled. romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF... romPost: Writing address to each *address... romPost: Reading address from each *address... romPost: DRAM march test passed... romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON... romPost: Enabling data cache... romPost: Data cache enabled. romPost: Enabling instruction cache... romPost: Instruction cache enabled. romPost: Writing address to each *address... romPost: Reading address from each *address... romPost: DRAM march test passed... romPost: PERFORMING DRAM WALKING-ONE TEST... romPost: DRAM Walking-one test passed. romPost: PERFORMING NV-MEMORY WALKING-ONE TEST... romPost: NV-MEMORY Walking-one test passed. romPost: Disabling data Cache... romPost: Data cache disabled. romPost: Disabling instruction cache... romPost: Instruction cache disabled. romPost: Enabling instruction cache... romPost: Instruction cache enabled. romPost: POWER-UP DIAGNOSTIC COMPLETE. Hel VxWorks System Boot Copyright 1984-1996 Wind River Systems, Inc. CPU: Tektronix HPP - PowerPC 740 Version: 5.3.1 BSP version: 1.0.7.1 Creation date: Mar 2 2003, 14:10:50 Press any key to stop auto-boot... 0 auto-booting... boot device : sm processor number : 0 file name : c:/vxboot/vxWorks.st inet on backplane (b): 192.168.0.1:ffffff00 host inet (h) : 192.168.0.2 gateway inet (g) : 192.168.0.1 flags (f) : 0x1008 target name (tn) : tds7000 startup script (s) : c:/vxboot/topscript.hw Initializing backplane net with anchor at 0x1e80000... done. Backplane anchor at 0x1e80000... Attaching network interface sm0... done done. Attaching network PC1 dio device driver installed interface lo0... done. Attaching DIO client... done. Loading c:/vxboot/vxWorks.st...1773508 Starting at 0x200000... Host Name: bootHost User: target Initializing backplane net with anchor at 0x16e0000... done. Backplane anchor at 0x16e0000... Attaching network interface sm0... done done. PC1 dio device driver installed Attaching network interface lo0... done. Adding 6008 symbols for standalone. ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R) ] ]]]]]]]]] ]]]]]] ]]]]]]]] ]] ]]]] ]] ]]]]]]] ]]]]]]]] ]]]]]] ] ]] ]]]] ]]] ]]]]] ] ]]] ] ]]]] ]]] ]]]]]]]]] ]]]] ]] ]]]] ]] ]]]]] ]]]] ]]] ]] ] ]]] ]] ]]]]] ]]]]]] ]] ]]]]]]] ]]]] ]] ]]]] ]]]]] ] ]]]] ]]]]] ]]]]]]]] ]]]] ]] ]]]] ]]]]]]] ]]]] ]]]]]] ]]]]] ]]]]]] ] ]]]]] ]]]] ]] ]]]] ]]]]]]]] ]]]] ]]]]]]] ]]]]] ] ]]]]]] ] ]]] ]]]] ]] ]]]] ]]]] ]]]] ]]]] ]]]]]]]] ]]]]] ]]] ]]]]]]] ] ]]]]]]] ]]]] ]]]] ]]]] ]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System ]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1 ]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5 ]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997 CPU: Tektronix HPP - PowerPC 740. Processor #0. Memory Size: 0x2000000. BSP version 1.0.7.1 . WDB: Ready. KERNEL: THERMAL CONTROL INITIATED Executing startup script c:/vxboot/topscript.hw ... dbFsIoctl: invalid code 3 ################### topScript starts ############################### cd "dbfs:c:/vxBoot" value = 0 = 0x0 ld < TekScope.o value = 23666688 = 0x1692000 ld < TekScopeSM.o value = 23666048 = 0x1691d80 pDbDev = ramDevCreate(0, 512, 1152, 1152, 0) new symbol "pDbDev" added to symbol table. pDbDev = 0x1693940: value = 23673184 = 0x1693960 = pDbDev + 0x20 pDBfs = dosFsMkfs("/db", pDbDev) new symbol "pDBfs" added to symbol table. pDBfs = 0x1691bc0: value = 23665696 = 0x1691c20 = pDBfs + 0x60 copy ("TekScope.DBF", "/db/TekScope.DBF") value = 0 = 0x0 overrideFPdefaults() value = 0 = 0x0 measurePPCtimebase value = 0 = 0x0 registerMemPartitionSizes ( 0x00000000 ) value = 0 = 0x0 semInitForQueueCheckLogMsg value = 21818112 = 0x14ceb00 initSysWaiter() value = 0 = 0x0 raxInit value = 0 = 0x0 paiInit done value = 17770744 = 0x10f28f8 = PaiBaseRegisterTable + 0x948 verifyAcqBoardID value = 0 = 0x0 updateAcqProcFirmware("dbfs:c:/vxBoot/acqProc8535.hex", "AT90S8535") 0x16987e0 (tShell): AVR chip type is AT90S4434; no programming attempted value = 0 = 0x0 updateAcqProcFirmware("dbfs:c:/vxBoot/acqProcMega.hex", "ATmega8535") 0x16987e0 (tShell): AVR chip type is AT90S4434; no programming attempted value = 0 = 0x0 cd "pc:" value = 0 = 0x0 raxInitializeDevices 0x16987e0 (tShell): >> Setting PLL to 1.25e+09 Hz. done 0x16987e0 (tShell): (Re)starting Acq Processor value = 23692720 = 0x16985b0 excHookAdd(stopStressForException) value = 17558416 = 0x10beb90 = stopStressForException dsyInit value = 21806600 = 0x14cbe08 dsyWPApplyNextRegs value = 17760620 = 0x10f016c = DsyRegisterTable + 0xab0 # remove '#' from next line to set powerup scope state to factory default: # NvramClearDb = 1 nvram_initFileSys value = 21801344 = 0x14ca980 TmgrInit("/db") value = 0 = 0x0 PhxProxyInit value = 20822528 = 0x13dba00 rtlInit value = 0 = 0x0 sysExtMemAddToPool memSysPartId,0x02000000,0x06000000 value = 0 = 0x0 hwAccount_init 0x16987e0 (tShell): >> Setting PLL to 1.25e+09 Hz. sysEnetAddrGet: f4:ce:77:de:35:ef value = 7 = 0x7 GpibInit value = 133285152 = 0x7f1c520 wfmMemInit(1) value = 47300320 = 0x2d1bee0 vertInstall value = 47293284 = 0x2d1a364 calConStatus = cc_init(2) 0x16987e0 (tShell): Reading 280 bytes of service cal data from EEPROM[0] into 0x 2d1a240 0x16987e0 (tShell): nvMem_read succeeded 0x16987e0 (tShell): Reading 66 bytes of service cal data from EEPROM[280] into 0 x2d1a300 0x16987e0 (tShell): nvMem_read succeeded 0x16987e0 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/0 0x16987e0 (tShell): cc_init: bank 0 chksum failed, NOT reset to factory 0x16987e0 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/1 0x16987e0 (tShell): cc_init: bank 1 chksum failed, NOT reset to factory 0x16987e0 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/2 0x16987e0 (tShell): cc_init: bank 2 chksum failed, NOT reset to factory 0x16987e0 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/3 0x16987e0 (tShell): cc_init: bank 3 chksum failed, NOT reset to factory 0x16987e0 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/5 0x16987e0 (tShell): cc_init: bank calConSta5tus chksum failed, NOT reset to fact ory = 0x16987e0 (tShell0x): cc_restoreBank: can't open file 13C:/vxBoot/calCons/426 014 0x16987e0 (tShell: value = ): cc_init: bank 614236 chksum failed, NOT reset to f actory = 0x0x16987e0efef (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/ upd7ateTrigCal 0x16987e0 (tShell): cc_init: bank value = 7 chksum failed, NOT reset to factory 00x16987e0 = 0x (tShell): cc_restoreBank: can't open file 0C:/vxBoot/calCons/ 8 0x16987e0 (tShell): cc_init: bank MathMeas8CreateTheMathandMea chksum failed, NOT res et to factory sur0xementLibraries16987e0 (tShell): cc_restoreBank: can't open file value = C:/vxBoot/calCons/471207094 0x16987e0 (tShell): = 0xcc_init: bank 2cf01409 chksum failed, NOT reset to fact ory 0x16987e0 (tShell initAcqMapp): ercc_restoreBank: can't open file C:/vxBoot/calCons/valu10e = 0x16987e0 (tShell0): cc_init: bank = 0x10 chksum failed, NOT reset to factory 00x16987e0 (tShell ): cc_restoreBank: can't open file C:/vxBoot/calCons/ 11 trigMapInit 0x16987e0 (tShell): cc_init: bank value = 110 chksum failed, NOT reset to factory 0x= 0x16987e0 (tShell0): cc_restoreBank: can't open file C:/vxBoot/calCons/ 13dsyMapInit 0x16987e0 (tShell): cc_init: bank value = 13 chksum failed, NOT reset to factory 00x16987e0 = 0x (tShell): 0cc_restoreBank: can't open file C:/vxBoot/calCons/ mat14hMapperInit 0x16987e0 (tShell): cc_init: bank value = 14 chksum failed, NOT reset to factory 00x16987e0 = 0x (tShell): 0cc_restoreBank: can't open file C:/vxBoot/calCons/ ut15ilMapInit 0x16987e0 (tShell): cc_init: bank value = 15 chksum failed, NOT reset to factory 4711800x4816987e0 (tShell): = 0xcc_loadV: CC_TRIGtrigLineGain2cef was 6e0; clip ped 0x16987e0 (tShell): cc_chkLimits: CC_TRIGtrigLineGain was TmgrHookup; reset to factory 0x16987e0value = (tShell0): initAcqMapper: Enter = 0x0 PhxProxyHookup value = 0 = 0x0 hookupAcqMapper value = 20165048 = 0x133b1b8 = AcqMapperRtlDataList MathMeasMapHookup value = 23692552 = 0x1698508 dsyMapHookup value = 23692656 = 0x1698570 utilMapHookup value = 23692688 = 0x1698590 rtlHookup value = 0 = 0x0 horizMapHookup value = 23692648 = 0x1698568 fastFrameMapHookup value = 23692672 = 0x1698580 trigMapHookup value = 23692680 = 0x1698588 vertMapHookup value = 23692672 = 0x1698580 spcMapHookup value = 23692672 = 0x1698580 autosetMapHookup value = 23692712 = 0x16985a8 timeSyncMapHookup value = 23692704 = 0x16985a0 auxTrigMapHookup value = 23692688 = 0x1698590 dpoMapHookup value = 23692680 = 0x1698588 TmgrStartup value = 46248912 = 0x2c1b3d0 PhxProxyStartup value = 46198368 = 0x2c0ee60 taskDelay(2) value = 0 = 0x0 gpibHwInitC value = 0 = 0x0 gpibTaskSpawn value = 46040768 = 0x2be86c0 gpibIoInit "/dbios/DBIO005","/dbios/DBIO006" value = 45940864 = 0x2bd0080 enablePowerupDiags = 0 enablePowerupDiags = 0x1311460: value = 0 = 0x0 runPowerupDiags dipSwitch = 0x0, enablePowerupDiags = 0, puMode=0 CalDiagPowerUpDiagsEnabled = 0 !! SKIPPING POWERUP DIAGNOSTICS !! 0x2b10940 (digHFTask): >> Setting PLL to 1.25e+09 Hz. 0x2b10940 (digHFTask): >> Setting PLL to 1.25e+09 Hz. 0x2b10940 (digHFTask): >> Setting PLL to 1.25e+09 Hz. value = 17780976 = 0x10f50f0 = SoftSwitchesRegisterTable + 0x48 rtlStartup value = 0 = 0x0 tsComp value = 0 = 0x0 ################### topScript ends ############################### Done executing startup script c:/vxboot/topscript.hw KERNEL: RUNNING TIME SLICED AT 10 TICKS PER SLICE! ->
