I have just received my Siglent SDS2104X Plus oscilloscope, specifically to do Bode plotting using my external Siglent SDG2042X AWG.
The plotting function works correctly if I use the internal AWG (free trial) but I cannot find the magic potion to get the two instruments to talk to each other via LAN.
Admittedly, I know nothing about LAN.
I am confused on how to set the IP, SubMask, and Gateway parameters on both the oscilloscope and the signal generator.
Nothing else connected ... can someone suggest a set of values to get the two communicating.
Presently, I get 'FAILED TO CONNECT TO AWG' response when testing the connection, so clearly I have lost my way.
I also see that both instruments have a USB Host connection, and I must admit I am clueless as to how to connect via USB. I don't think I have ever seen a USB cable with the same host connector on each end.
Latest firmware installed ... thank you so much for taking the time to read of my woes. I am hopeful others have done something similar but successful.
Daniel
