Author Topic: Tektronics TLA704 PCI upgrade  (Read 2126 times)
Offline aspTopic starter
« on: July 22, 2022, 09:03:03 am »
Hi
   If somebody wants to get the PCI working on a Tek TLA704 below you can find the steps to accomplish that:
1. Unsolder all the pins for the PCI connector on the board and put in a PCI connector (120 pin)
2. Populate R25 and R23 with a 0 Ohm resistor (5 and 3.3V) (found on the top of the board near the PCI Connector)
3. Populate R4 with a 33 Ohm resistor (PCI IDSEL) (found on the top of the board near the PCI Connector)
4. Populate R165 with a 33 Ohm resistor (PCICLK) (found on the bottom of the board on the opposite side of the PCMCIA connector under the crystal)
This will get the PCI working BUT the BIOS will not assign any IRQs to the PCI board and when booting you will get this:
Warning: IRQ not configured - Pci at slot 01
    Bus:00, Device: 0E, Function:00
System Configuration Data updated
Press <F1> to resume,  <F2> to Setup
regardless of the settings you do in BIOS.
If somebody could take a look at the bios (maybe someone has RFDes contact info) and see it they can change/mod it to support IRQ assignment it would be awesome
The PCI cards will be detected in Windows but it won't start. Windows will report that the device does not have an IRQ assigned to it by BIOS
Attached you can find the latest bios 1.00.14
   For your info when I started this I wanted to add a PCI USB card so that I can add a soundcard to the device in order to play some old games on the device with sound  :)
« Last Edit: July 28, 2022, 07:00:17 pm by asp »
Re: Tektronics TLA704 PCI upgrade
« Reply #1 on: July 25, 2022, 07:22:12 am »
I did manage to unpack the part of the bios that deals with the whole init thing but I am kind of stuck here. I would need somebody with ASM experience in dealing with BIOS
I have attached the decrypted bios part for people that want to have a look
Offline Per Hansson
« Reply #2 on: July 28, 2022, 08:13:29 am »
Maybe this is useless info but if you are really stuck it could maybe help:
In the old days there was a project to add support for AGP cards with two IRQ devices, the extra one for the built in HDMI sound card.
Many old boards did not support this and you had to edit the DSDT table in the BIOS to add that support in.
In the DSDT table is also the PCI definition, so you could have a look at this and see if it is in anyway a step in the right direction:
https://www.techpowerup.com/forums/threads/ati-hd-agp-card-with-hdmi-audio-problems-read-this.106690/
Here is a list of boards that use the same chipset: FW82439HX (430HX "Triton II") with a 82371SB (PIIX3) south bridge:
https://www.ultimateretro.net/en/motherboards/?chipsetId=276
Then just start looking for a board with PCI slots that uses the Phoenix BIOS, here is one:
Siemens Nixdorf System Board D969: https://www.ultimateretro.net/en/motherboards/4507
Maybe you could use its DSDT table if you are able to extract it from the BIOS...
P.S: Of course first double check that your board actually uses the same chipset...
« Last Edit: July 28, 2022, 08:46:19 am by Per Hansson »
« Reply #3 on: July 28, 2022, 02:52:12 pm »
I did try to get the ACPI from both windows and linux and it's not there.
In linux this are all the lines from dmesg that contain acpi:
[    0.093403] API: Early table checksum verification disabled
[    0.097258] ACPI BIOS Error (bug): A valid RSDP was not found (20190816/tbxfroot-210)
[    0.144814] Kernel command line: BOOT IMAGE=/boot/umlinuz root=PARTUUID=feblefb9-02 rootwait console=tty0 console=ttyS0,115200n8 noinitrd acpi=force
[    1.121610] ACPI: Interpreter disabled
[    1.316789] pnp: PnP ACPI: disabled
with APM enabled in BIOS, so I don't see a way to extract the DPDT since I can't get ACPI to show up
Maybe the BIOS does not implement ACPI?
Also there is no /proc/acpi or /sys/firmware/acpi
Offline dxl
« Reply #4 on: July 28, 2022, 04:17:45 pm »
TLA704's are so old that i doubt they ever had ACPI.
Offline Per Hansson
« Reply #5 on: July 28, 2022, 04:29:11 pm »
There is a new BIOS here that adds APM support, it requires a new LCD though, because it only works at 800x600:
https://www.eevblog.com/forum/testgear/tla704-logic-analyzer-help/
Not sure if it is the same BIOS as this guy made, wont hurt to ask:
https://forum.tek.com/viewtopic.php?t=136518
« Reply #6 on: July 28, 2022, 06:53:26 pm »
I have tested the device with the updated BIOS and it's the same thing in linux (win98 won't boot with the new bios)
Below you can find a screenshoot from HWINFO for DOS running on an external monitor with the new BIOS, and as you can see it has ACPI disabled as well. It's exactly the same output for the original bios here as well as in linux regardless of the bios flavor I use.
PS: I did message Jim as he is a member of the forum here but he is busy with other tasks
« Last Edit: July 28, 2022, 06:58:39 pm by asp »
Offline rfdes
« Reply #7 on: February 01, 2023, 07:38:44 pm »
Curious if this project ever completed successfully.
My understanding was that the PCI connectors were not true PCI, i.e. they had some odd signals.  The thought was they were used as development test connectors.
« Reply #8 on: February 01, 2023, 07:50:16 pm »
With the hardware changes made to the board you will get a true PCI (it even detects the boards that you put in BUT the bios does not include code to allocate IRQ’s to the board) so basically you cannot use any pci board in it. I was thinking to get a pIRQ line from some other device and maybe it will work sharing the IRQ. For my purpose I want to add a sound card in via USB
I was thinking to port an old version of coreboot but it’s too much work for something that I don’t find that rewarding
« Last Edit: February 01, 2023, 07:53:09 pm by asp »
Offline rfdes
« Reply #9 on: February 01, 2023, 10:31:24 pm »
Are we talking about the 120 pin connector that is NOT populated?
I did some multimeter testing and noticed some of the pins had the wrong power supplies connected.  In particular, the one of the -12V pins had +5V on it.  I also seem to remember that the orientation of the connector was going to be a problem as it is configured for 5V PCI cards.  Is this what you discovered?
« Reply #10 on: February 11, 2023, 09:07:07 pm »
Yes. It's the unpopulated connector that is a PCI
-12 and +12 are not mandatory. Actually on the boards that I have tested, the -12 and +12V pins are floating (and I do not have a board that uses either -12 or +12V at hand)
If you populate all the resistors as described in the first post you will get a working PCI (not 100% compliant but working), but the issue with IRQ assignment remains valid as the bios will not assign an IRQ to the board. I have attached some images and you can see the PCI boards connected and detected by the equipment
Offline nctnico
« Reply #11 on: February 11, 2023, 11:18:58 pm »
Did you try a different PCI card? Maybe the BIOS just doesn't recognise this particular PCI card.
« Reply #12 on: February 12, 2023, 02:15:37 am »
Yes! I have tried 6 different pci-to-usb cards (2 of them are in the pics in the previous post). I have also tried a PCI sound card and a Video capture card and all have the same behavior of not getting IRQs.
Right now I have take down the motherboard and added a socket to it in order to upgrade de cpu to a Pentium MMX 233.
So unless somebody manages to mod the bios and add IRQ assignment, nothing can be done unfortunately!
Offline rfdes
« Reply #13 on: February 14, 2023, 03:34:28 am »
thanks for the response.
Are you sure there is not another jumper that enables one of the 4 interrupts?  I have heard that it is possible to directly wire the interrupt but I have no hands on experience with this and if it is even possible.  Just something I read once in the past.
It may also be possible to assign an interrupt from within Device Manager. If you haven't already, check the Device Manager application.
« Reply #14 on: February 14, 2023, 09:47:43 am »
I have checked the board and INT[A:D]# from the PCI slot go directly to the southbridge chip to PIRQ[A:D]# pins. unfortunately the rest of the chips use direct irq adressing having their irq lines routed to irq pins on the southbridge.
My best guess is that the only thing that needs fixing is some register in southbridge initialization sequence (or at least that is what I hope) (PIRQRC[A:D]). That is because by default it seems that PIRQ routing is disabled
I have added a screenshot with the relevant part of the documentation
« Last Edit: February 14, 2023, 09:55:54 am by asp »
Offline rfdes
« Reply #15 on: February 18, 2023, 01:02:15 am »
Hmmm -
I might have some spare time in the next month to take a closer look at this.  If so, I'll keep you in the loop.
Jim
