Our E4407B at work developed an "LO Unlocked" error and decided to take a look. I have repaired two ESA's with this problem, same IC as in Signal Path repair videos. But when I started looking at the RF Deck PCB, it's different! Labeled as p/n E4403-20100. The divider chain has different parts. Uses an Agilent 1GC1-4210 divider (similar to HMC862) divide by 2/4/8/16 I believe, selectable via 3 inputs. It's driven by a differential receiver/driver MC10EL16.
CANNOT find a CLIP for this one!
But the MC10EL16 has 0 dBm coming in, and -15 dBm coming out.
Looks suspicious!
Mark
