Hi Guys
I have a thermal problem with my Tek2755P.
At some temperatures it works ok without any errors, and at other temperatures it gives the message:
Frequency control Failure Tuning failure - 1ST LO ( for span below 10MHz )
Error 7 Oscillator corrections are disabled
Has anyone had a similar problem and successfully solved it ?
Which plug-in card or component caused the error ? .....Can anyone help ?
It's annoying when something fails during the measuring process (usually at around 20°C ambient temperature),
then I have to either cool it down or heat it up to make it work again.
Vy 73 de OE7DBH
Darko
