Author Topic: Tektronix blue filter  (Read 386 times)
Offline harrison@cs.unc.edu
« on: June 13, 2021, 08:54:56 pm »
Some of this may be helpful to others that own Tektronix 'scopes.
I wanted to replace the smoked filter on my 7603, but could not find one for a reasonable cost.
Lowes has a small piece of 0.080 transparent plastic for less than 4 dollars. I bought a piece and cut it with a jig saw to match the size of the
smoked filter. I then glued a piece of GamColor theater gel to the back side of the plastic to make the filter. It seems to work well. It isn't the
same as the one from Tektronix, but it is the same color and was inexpensive.
So...plastic piece $ 3.78
GamColor #790, $9.95 ( 20 x 30 sheet )
Hope this helps someone.
The following users thanked this post: YetAnotherTechie
Offline ps
Re: Tektronix blue filter
« Reply #1 on: June 19, 2021, 12:25:04 pm »
In case someone needs an even more economic solution, cut the screen from the cover of a CD jewelcase.
Online David Hess
  • DavidH
« Reply #2 on: June 21, 2021, 01:33:54 am »
Art supply stores have transparent colored plastic film which may be the right shade of blue.
Be careful about replacing the colored plastic filter if a clear one is not also installed because it serves as an explosion shield if the CRT should shatter.
