Could you explain the THD digitizer limitations.
I have available in my area a broken DSA602A that I might be able to use as a parts unit for low dollars.
Of course I realize this FFT only good to -60 to -70dB
Data sheet from DSA 602A
Measurement System
Amplitude: Min, max, mid, mean, p-p, gain, RMS, overshoot, undershoot, area +, area -, and energy.
Timing: Rise, fall, width, delay, main-to-window trigger time, period, propagation delay, cross, phase, frequency, duty cycle, and skew.
FFT: Fundamental track, harmonic amplitude, frequency, and total harmonic distortion.
Statistics: Available for any measurement listed above for both live acquisitions and groups of stored waveforms.
Cursors: Single or dual dots, split or paired mode, horizontal and vertical bars, and measurement-zone delimiters. Delta volts, delta time, 1/delta time, and slope.
Waveform Processing
Waveform Functions: Absolute value, average (exponential and summation), convolution, correlation, delay, dejitter, differentiate, envelope, exponential, FFT filter, FFT integrate, interpolate, log, natural log, pulse, signum, smooth, and square root. Live waveforms can be changed by using adjustable parameters.
Arithmetic Operators: Add, subtract, multiply and divide.
FFT: Magnitude and phase; real and imaginary; inverse FFT, correlation, and convolution; six window functions; Typical Noise Floor: -60 dB; -70 dB with averaging.
Act on Delta: Save, repeat, chime, SRQ, and hardcopy.
Histograms: Vertical or horizontal histograms generated from a user-defined portion of any waveform. Statistical information is provided for histogram data.
