Author Topic: Getting TekVisa to work with Keysight 82357B  (Read 158 times)
Offline perdrix
« on: March 07, 2020, 04:22:04 pm »
So I have an 82357B adapter, how do to I get the Tektronix software to talk to a TDS3064B hung off this?
I installed the KeySight Instrument Control Bundle to get the driver for the 82357B.   Keysight Connection Expert sees GPIB0::14::INSTR and KeySight Interactive IO tool can send *IDN? and get the expected result:
TEKTRONIX,TDS 3064B,0,CF:91.1CT FV:v3.39 TDS3GV:v1.00 TDS3LIM:v1.00 TDS3FFT:v1.00 TDS3TRG:v1.00
BenchVue appears to be a waste of space - it doesn't even know about a 3458A!!!
All that Tektronix OpenChoiceDesktop shows me when I press "Select Instrument" is ASRL1::INSTR
So please what's the magic incantation to make this all work?
Thanks
Online joeqsmith
Re: Getting TekVisa to work with Keysight 82357B
« Reply #1 on: March 07, 2020, 04:35:14 pm »
I tried to use TekVISA at one point.  It wasn't used to talking to the instrument through GPIB but rather to use the Ethernet.  For GPIB, I just controlled it like any other GPIB instrument.
In my case, that particular bit of equipment was actually slower using TekVISA with Ethernet than using GPIB!!    :-DD
In your case, the Tektronix software may not support the Keysight GPIB controller you are trying to use.
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
