Author Topic: Tektronix Iconnect Software 80SICON wanted TDS8300 TDS8300 DSA8300  (Read 1263 times)
Offline JuliusJTopic starter
First post and I am asking for help. Isn't that the same for most of us?
I am trying to locate a software package for the Tektronix sampling scopes. It is the 80SICON  - Iconnect.exe
Anyone out there have a copy of this running. It requires a dongle, which I already have.
Thanks kindly.
Offline d37duck
Re: Tektronix Iconnect Software 80SICON wanted TDS8300 TDS8300 DSA8300
« Reply #1 on: April 27, 2023, 05:19:53 pm »
Hi
Hi, I’ll swap you an IConnect CD copy, described below, for a code of your IConnect dongle.
I have a CD image of the disk pictured in the attachment, IConnect 80SSPAR Tek# 063-3897-04. The disk is supposed to work on all Tek TDS8000 family scopes including DSA8300.  I have a DSA8200 and installed it.  I can adjust differential signal alignment with the installation, but I need the dongle for TDR Line analyzes.
I don't have the Sentinel Superpro dongle for IConnect. My knowledge of the dongle is: and image can be read from it and the written into another Superpro dongle.  There is a company called SakeKey International ( https://www.safe-key.com/software.html ), and others like them, that provide dongle copying service.  I think Sentinel's parent company tries to prevent this. They required a dongle driver and dongle protector to be installed with the IConnect installation.  I assume this means the image read is altered.  I also assume SakeKey figured out a way around if.  There is an article about hacking the driver to eliminate the dongle, see Sentinel_Dongle attachment.
My opinion is all Sentinel parallel port dongles are made from 93C46 EEPROMs (or there die) with some digital logic (programmed PLD) to interface with the parallel port.  I have software that reads and writes parallel port Sentinel dongles with source code.  It uses x86 I/O read and write instructions to read and write the three registers in PC’s parallel port hardware. I believe an exact image of the dongle's EEPROM contents can be read with this software with no drivers or protectors install and written back to a second one. With luck it will work.
« Reply #2 on: July 13, 2023, 05:14:29 am »
Sorry for the late response.
Thanks for your offer, however I was able to locate the software.
