Products => Test Equipment => Topic started by: tektech on March 09, 2023, 08:25:52 pm
Title: Tektronix 754D knob/button panel interchange
Post by: tektech on March 09, 2023, 08:25:52 pm
I need a button/knob panel for a 754D scope. The panels from other models and generations look visibly identical. Anyone know
if all these other model's can be swapped into a 754D?
Title: Re: Tektronix 754D knob/button panel interchange
Post by: tautech on March 10, 2023, 12:48:51 am
Welcome to the forum.
Sphere might have some:
https://www.sphere.bc.ca/test/tekparts.html (https://www.sphere.bc.ca/test/tekparts.html)
Or there might even be a 3D printed model here:
https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/ (https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/)
Post by: tektech on March 13, 2023, 06:25:44 pm
So anyone know if all the similar models button panel will interchange?
Post by: TERRA Operative on March 14, 2023, 02:37:52 pm
All TDS500/600/700/800 series scopes use the same knobs. They are freely swappable.
What knob do you need? I may have a spare.
Post by: AVGresponding on March 14, 2023, 06:35:16 pm
I think it's the panel itself he's asking the question about, rather than the knobs or buttons
Post by: TERRA Operative on March 14, 2023, 11:23:13 pm
Ah, well, yes. I should read more closely... :D
The front panels are interchangeable, mostly.
The main difference is the prescence or absence of the purple DPO button adjacent to the large knob.
A TDS754D has the DPO function so you will want a front panel that also has this function too. I believe it makes no real difference if it comes from a different model or revision.
My offer still stands though, let me know what you need exactly and I'll see what I have (if I don't have a complete panel, I might have the parts to repair yours)
Post by: tektech on March 24, 2023, 07:28:20 pm
Hey thanks for the offer TERRA, I found a complete panel from a 540B and it seems to work just fine on the 754D for anyone looking in the future.
Thanks for all the replies!
Post by: james_s on March 24, 2023, 07:52:43 pm
Sounds like it would be missing the DPO function if your scope is a D series though.
Post by: tektech on March 28, 2023, 02:40:14 am
I did not try the button but I thought the InstaVu was what became DPO in the later models?
