My customer which has the TBS2004 also has a Rigol 1052; everyone is using the TBS2004 if they can.
Not that surprising, considering the DS1052E is a simple scope from 2008 with tiny screen, limited functionality and an UI which was 'inspired' by the early TDS scopes. Obviously a scope which came out 10 years later and with a bigger screen is nicer to use than that old Rigol.
However, it would be a mistake to conclude from that that the TBS2000 is the better or nicer to use scope compared to other modern day entry level scopes. Because current entry-level scopes like the Rigol DS1054z (which is already 6 years old) or the Siglent DS1000X-E are a far cry from that old DS1052E. Even more so the Rigol MSO5000 and Siglent SDS2000X+, both which are within the TBS2000(B)'s price range.
I just watched a video (Tek's 'TB2000 Technical Overview') on YT, and frankly the TBS2000 seems to be a lot closer to older simple scopes like the old Siglent SDS1000CML Series (a $299 scope) than to the entry-level scopes we have today, both in UI and functionality (leaving the educational content such as the explanation of 555 timers of the TBS2000 aside because it's of little use outside education).
The TBS2000 UI actually remembers me a lot of the Hantek DS4000 (another simple scope).
The current standard of entry-level scopes like Rigol DS1054z, Rigol MSO5000, Siglent SDS1000X-E and Siglent SDS2000X+ have evolved quite a lot from that.
Let's not forget Tek's most important features: the largest discounts off list (A), the oldest "nobody gets fired for buying X" reputation (B), and the comprehensive warranties (C). If you're the pointy haired boss, what use do you have for bits, MHz, options, and wfm/s? Hell, even absolute savings don't matter, it's not your money anyway. But you *can* brag about A on your resume, hedge against big mishaps with B, and let C transform small mishaps into demonstrations of your own supreme foresight. It's the perfect scope!
At least point (A) is definitely wrong, Tek's incentives are amongst the lowest in the industry (although they have started to become a bit more flexible, very likely down to the economic pressure coming with dwindling sales).
As to (C), the warranty is actually the same as you get from Rigol and Siglent. Or any other manufacturer.
You're somewhat correct with (B), although the same can be said about Keysight (which was Agilent which was HP), LeCroy and Rohde & Schwarz. Actually, these three names have, in general, a much better reputation than Tektronix today.
Also, don't forget that the number of us old farts who knew Tektronix from the analog scope days is getting lower and lower.
