Author Topic: Tektronix Oscilloscope Probe Alignment tool.  (Read 2724 times)
Offline youbecha
« on: January 01, 2014, 03:18:27 am »
I have a 6139A probe that needs a bit of adjusting...but no tool was included.
I peeked in the adjustment hole to see what kind of tool it takes, and I can't figure out if is a screwdriver or socket wrench.
Screwdriver won't touch it.
What does the alignment tool end look like, and what can I substitute?
Thanks.
Offline sachleen
    • My Site
Re: Tektronix Oscilloscope Probe Alignment tool.
« Reply #1 on: January 01, 2014, 03:30:36 am »
This page has some info on it: http://www.csus.edu/indiv/t/tatror/EEE_117_Lab/3017_Test_Equipment/Tektronix%20P6139A%20Probe.pdf
SCREWDRIVER:ADJUSTMENT TOOL
Tektronix part number: 003--1433--02
Offline pickle9000
« Reply #2 on: January 01, 2014, 04:00:22 am »
The tool itself is in most cases plastic. If you happen to have a set of tv adjustment tools (as they used to be called) you should be able to find what you need. Other than that you will need a chunk of plastic rigid enough to act at the bit and file or carve it into the correct shape. Try the plastic shaft off of a childs water-paint brush. But don't let the kid catch you.
Offline youbecha
« Reply #3 on: January 02, 2014, 01:58:40 am »
Thanks all, I found Cal Test Electronics CT3648 Deluxe Oscilloscope Probe Trimmer Tool (of course only in quantities of 10...)  Its reference sheet says it replaces that Tektronix part...we shall see...
