Author Topic: Tektronix P6201 & 1101(A)  (Read 1375 times)
Offline Antonio90Topic starter
« on: March 12, 2024, 12:36:31 pm »
Hello,
I have a Tektronix P6201 active FET probe, but haven't been able to find a reasonably priced matching PSU.
Googling around a bit, I found a post stating that the pinout on one of the manuals had the +15 and -15V pins swapped around.
Could someone with the PSU (or having made a substitute) confirm the pinout on the attached doc is correct?
Re: Tektronix P6201 & 1101(A)
« Reply #1 on: March 12, 2024, 03:10:45 pm »
It was correct.
Just in case someone searchs for this same question. The red wire is +15V, the white one, -15, and the black wire, along with the shielding is ground (common with scope inputs)
