Author Topic: Tektronix P6245 Active Probe issues with config data  (Read 697 times)
Offline snoopy
    • Analog Precision
« on: March 03, 2017, 12:11:24 am »
Hi
Just got a 2nd hand Tek P6245 Active Probe. Probe seems to work but the scope (TDS784A) cannot read the configuration data from the probe and as such cannot run a probe compensation procedure which results in "Probe comp failed".
I note that the probe has TDS500/600 written on it but I thought the newer scopes would still be able to read the data. What data is stored in the EPROM ?
Any thoughts ?
Cheers
