Products => Test Equipment => Topic started by: snoopy on March 03, 2017, 12:11:24 am
Hi
Just got a 2nd hand Tek P6245 Active Probe. Probe seems to work but the scope (TDS784A) cannot read the configuration data from the probe and as such cannot run a probe compensation procedure which results in "Probe comp failed".
I note that the probe has TDS500/600 written on it but I thought the newer scopes would still be able to read the data. What data is stored in the EPROM ?
Any thoughts ?
Cheers
For those interested in this probe I have uploaded all of the information I have on it which includes schematics, EEPROM dumps etc.
cheers
Hi snoopy,
Thanks for the Tek 6245 data download, nice work. Please tell us what equipment you used and your procedure for recording the data.
Regards,
Hi snoopy,
Regards,
It was a while ago but I picked up a small EEPROM programmer from ebay I think called CH341A programmer and used that to read and write the data on the probe EEPROM (24C02). From memory I may have used EZ hooks connected directly to the pins on the probe scope connector whilst it was not connected to the scope of course. Supply required.
cheers
mind to tell what was the issue with config data? i have the Tek P6245 probe but dont have a Tek scope. was bought faulty with some ribbon carbon traces broken... i wonder how Tek scope communicates with the probe? does the Tek scope modify the eeprom content during recalibration?
A couple of the probes had blank data so I copied data from a another working probe. Not sure how they got corrupted but that's how I got them. Oddly enough according to the schematic I mapped out, the WP pin appears to be floating. Not sure if it has an internal pullup ?
cheers
