Hi
I have a Fluke 87V.
Looking through the manual I see they say "use 80TK Thermocouple" I have and RTD (Pt1000) and used it with my meter.
Measurements:
Temp (C) Resistance
0 857 ice water
34.5 1113 body temp
100 1600 boiling water @ sea level
The 34.5 value was calculated from the other measurements.
My question:
Why does Fluke only cater for thermocouples to give out a converted temperature reading?
It would have been nice if they could add a facility to convert resistance readings directly to temperature readings after the user did some sort of a rudimentary calibration, ice water & boiling water. With the knowledge that there will be +/- 2C errors
This would be good enough for some applications. I don't work with temperature readings often so am I a bit naive here?
