I agree with all srb1954 said. These TDS 500/600/700 series scopes are good machines, if a bit large, once a little maintenance is done.
kellyjo_13 is the seller on ebay with the replacement NVRAM chips. I can vouch for the quality, I have them in my TDS784D and TDS794D and they work great.
https://www.ebay.com/sch/i.html?_nkw=Tektronix+TDS784D+700x+600x+DS1486+and+DS1250YI am currently designing my own versions of both chips, the designs of which I'll release on these forums once they are working.
Check your power supply for Rifa caps (there will be 4) and replace C17, if present (Usually on the older revision PSU's used in earlier scopes like the A and B series), see the image below for details.
Also, the A and B series scopes usually need all new SMD capacitors on the top Processor board, and the bottom Acquisition board, so be prepared for that too.
The capacitors are practically guaranteed to leak sooner or later, so it is a definite requirement to be done.
