sadly no
You have many tds7xxx related threads here at eevblog the main difference where the ram amount you could use etc ... and motherboard chipset etc ..
And these motherboard are kinda crippled in a way, you can not set the bios easily unless creating some kill cmos trick to invoke the computer bios ..... because in the video settings, if wrongly settled up, can fuck up the front display into weird resolutions (been there loll was problematic to reset)
Change the motherboard cell too if possible, but theses scope are something to open loll lots of screws and very fragile to remove the computer board, be very "visual" and don't pull hard if you sense resistance, tons of screws i said loll mark where they are on the aluminum shield before removing it ...
I think you can use xp, on archive.org you have xp's cd-roms archives, some of them have updates usb drivers in them etc .... you boot from it, and do the setup
Ex: https://archive.org/details/WinXPProSP2ENG
The Sp3 pack is still available from Microsoft ... install it after the xp installation first .... and after a reboot you can remove some crap like msn, outlook etc ....
Done that on our 7254 "B" .... put it into classic desktop mode etc ... it will be less ressource hungry, no background image (black is better) helps too
And in the device manager, you will see what errors you have ... report them to us, you go in their hardware material " VID&PID " properties
The tek package should resolve a few if not all of them, but you need the touch panel and mostly the special interface card drivers who goes between the scope side and the computer side ....
One thing at the time ...
Other members may chime in loll i'm not an expert in theses
Its a matter of time before the original hdd dies .... our dallas chip are dead in our scope, but SPC works and everything else works .... loll
