[rerouted from TEA thread]
Well, besides not having any clue what program is that from
It's CEC488/KPC488.2 8bit ISA card ROM.
The support disk image I found should have had headers but none were present.
Github had something, but icpdas ftp has more.
If Keithley's ISA card has a ROM chip then it's most likely backwards compatible.
But by default newer cards have ROM disabled so default test fails if ROM is needed.
CEC is noting that only oldies from '80s are using the ROM.
It's a very old construction so it should be known by many.
I guess it would be close to easiest 1st level, a controller construction that supports old software.
After that the 2nd level, the new application software, would be much easier.
Emulating TI/NEC chip registers and their addresses is clearly minimum for FAS.
ROM functions,
"short" is a len parameter length of one byte, must be from PC/XT era and for backwards compatibility.
00 init
03 transmit "short"
06 receive "short"
09 send "short"
0c spoll
0f ppoll
12 init 2
15 ? "short"
18 in base+4, test 2
1b in base+4, test 4
1e transmit
21 receive
24 send
27 enter
2a DMA?
c8 tarray (cache RAM)
cb rarray (cache RAM)
ce dma2
ROM code has a fixed I/O address.
c800:0000 e9 dd 00 JMP LAB_c800_00e0
c800:0062 b8 02 dw 2B8h
LAB_c800_00e0 XREF[1]: c800:0000(j)
c800:00e0 55 PUSH BP
c800:00e1 8b ec MOV BP,SP
c800:00e3 50 PUSH AX
c800:00e4 52 PUSH DX
c800:00e5 b0 02 MOV AL,0x2
c800:00e7 2e 8b 16 MOV DX,word ptr CS:[0x62]
62 00
c800:00ec 83 c2 05 ADD DX,0x5
c800:00ef ee OUT DX,AL
From CEC's ieee-c.h
Push parameters to stack from left to right.
#define initialize(addr,level) ieee488_initialize(addr,level)
#define transmit(cmd,status) ieee488_transmit((char *) (cmd),0xFFFF,(long int *) status)
#define receive(s,maxlen,len,status) ieee488_receive((char *) (s),maxlen,(unsigned long *) len,(long int *) status)
#define send(addr,s,status) ieee488_send(addr,(char *) (s),0xFFFF,(long int *) status)
#define enter(s,maxlen,len,addr,status) ieee488_enter((char *) (s),maxlen,(unsigned long *) len,addr,(long int *) status)
#define spoll(addr,poll,status) ieee488_spoll(addr,(char *) poll,(long int *) status)
#define ppoll(poll) ieee488_ppoll((char *) poll)
#define tarray(d,count,eoi,status) ieee488_tarray((void *) d,count,eoi,(long int *) status)
#define rarray(d,count,len,status) ieee488_rarray((void *) d,count,(unsigned long *) len,(long int *) status)
#define transmit(cmd,status) ieee488_transmit((char far *) (cmd),0xFFFF,(int far *) status)
#define receive(s,maxlen,len,status) ieee488_receive((char far *) (s),maxlen,(unsigned int far *) len,(int far *) status)
#define send(addr,s,status) ieee488_send(addr,(char far *) (s),0xFFFF,(int far *) status)
#define enter(s,maxlen,len,addr,status) ieee488_enter((char far *) (s),maxlen,(unsigned int far *) len,addr,(int far *) status)
#define spoll(addr,poll,status) ieee488_spoll(addr,(char far *) poll,(int far *) status)
#define ppoll(poll) ieee488_ppoll((char far *) poll)
#define tarray(d,count,eoi,status) ieee488_tarray((void far *) d,count,eoi,(int far *) status)
#define rarray(d,count,len,status) ieee488_rarray((void far *) d,count,(unsigned int far *) len,(int far *) status)
#define srq ieee488_srq
#define setport(bd,io) ieee488_setport(bd,io)
#define boardselect(bd) ieee488_boardselect(bd)
#define dmachannel(c) ieee488_dmachannel(c)
#define settimeout(t) ieee488_settimeout(t)
#define setoutputEOS(e1,e2) ieee488_setoutputEOS(e1,e2)
#define setinputEOS(e) ieee488_setinputEOS(e)
#define enable_488ex(e) ieee488_enable_488ex(e)
#define enable_488sd(e,t) ieee488_enable_488sd(e,t)
#define listener_present(a) ieee488_listener_present(a)
#define gpib_board_present ieee488_board_present
#define gpib_feature ieee488_feature
BTW,
I had a rude awakening once.
My cli/sti test was very slow, then I bought the Unauthorized Win95 by A. Schulman.
Back in the day there were exceptions, can't remember how many.
Maybe virtual DOS can have a filter driver for ins and outs.
That driver could also create logs and so be a sniffer.
