Author Topic: Tektronix TDS220 repair  (Read 21360 times)
Offline blade
Re: Tektronix TDS220 repair
« Reply #25 on: September 29, 2023, 04:12:27 pm »
I'm having the same issue, i traced it back to the flash memory. there is a footprint marked U430A that is for the same chip, but in Standard 48 pin TSOP. I probed all pin connections and ended up finding that control pin 28 (OE#)  is cut off and i donn't know where it is supposed to connecto to since i do not have another board. Basically  flash is unreadable without this pin.
« Last Edit: September 29, 2023, 04:15:39 pm by blade »
