Did anybody ever succeed in repairing a Tek TDS3000B series scope that is stuck on the splash screen with known good NVRAM and PSU?
I have both a TDS3052B and TDS3034B with the same problem: both get stuck on the splash screen, no floppy sounds, no relay sounds, no front-panel lights.
I have fixed my share of these scopes, but never had this problem, nor did I see in any of the threads in this forum any report of fixing a scope with these symptoms (though the problem was discussed more than once).
I would make the following notes:
- By replacing parts with a working TDS3064B I know for certain that the NVRAM is not the issue, nor is the PSU or the battery board.
- All supply rails (+5V, -5V, +3.3V) generated on the main board also test fine by comparison to the working TDS3064B.
- Both clock chips on the main board are fine.
I have seen mentions of possible bad RAM, Flash ROM, or CPU needing re-balling, but no mention of anybody actually verifying any of these suspicions.
