does anyone know why a TDS3054 shows a 'Low resolution' warning from around 315MHz onwards for the frequency measurement ?
10K points at 5GS/s, that should be more than enough for a frequency measurement up to 500MHz, no ?
I'm using a sine wave, 500mV pk-pk, 50 ohm, real-time sampling
I first thought my siggen was at fault (maybe it was, but it died in the meantime...), but now I've got a calibrated R&S SML, so that won't be the issue... then I thought "well, it's because I hacked it from 100 to 500MHz", but I just checked with a 'native' TDS3054, and it's exactly the same ....
I'm a software guy, so sorry if I'm missing the basics here... ;-)
