Author Topic: Tektronix TLA7012 Dim Screen  (Read 868 times)
Offline OmicronTopic starter
« on: June 03, 2021, 06:31:53 am »
I have a TLA7012 logic analyser that I use on occasion. It hadn't been powered up in a long while and when I wanted to use it again the backlight was very dim, to the point of the screen being barely visible at all. My fist thought was that either the backlight or the inverter were bad, but it turned out to be something completely different that I hadn't expected.
The BIOS has a setting that determines how the backlight is controlled. It can be set to "I2C" or "PWM". The default is "I2C" but the TLA actually needs it to be "PWM". When the CMOS battery on the motherboard dies, the setting reverts to "I2C" and you end up with a dim screen. Replacing the battery and selecting "PWM" in the BIOS fixed the issue.
I found this surprising, so I post it here in case anyone else runs into this issue.
The following users thanked this post: nctnico
Offline calibrationfixture
Re: Tektronix TLA7012 Dim Screen
« Reply #1 on: March 26, 2023, 05:50:55 am »
Found this topic by accident. My TLA7012 had also a flat MB Battery (and corrupt HDD). After the HDD Rebuild (Windows XP, TLA Application V5.1 and the whole Array of needed separate Drivers) I have now a TLA7012 with bright Display (100% Initial Brightness: Default Setting) including the I2C setting. An acquintance of mine also pointed me to this issue, but in my case clearly it wasn't needed to change the setting. This morning I changed the setting to PWM out of curiousity. The result: no observed difference. In addition: it is an Early TLA7012 without Touchscreen. Anybody any ideas?
Calibrationfixture
« Last Edit: March 26, 2023, 10:42:09 am by calibrationfixture »
