Products => Test Equipment => Topic started by: alpher on December 07, 2019, 01:12:11 am
Title: Tektronix tunnel diodes, how to test ?
Post by: alpher on December 07, 2019, 01:12:11 am
Hi, just bought a few of the rare 152-0177-02 tek tunnel diodes.
They're obvious pulls, is there a simple way to check them if they're any good?
I don't have a curve tracer, tried a simple check with 100 \$\Omega\$ resistor and 100Hz ramp signal from function gen (https://hackaday.com/wp-content/uploads/2019/04/nr-curve-tracer_had.png)
From here : https://hackaday.com/2019/05/08/fun-with-negative-resistance-jellybean-transistors/
But all I get is a straight line like resistors :-//
Afraid to damage the quasi unobtanium diodes, can anyone suggest a better circuit to test them?
Title: Re: Tektronix tunnel diodes, how to test ?
Post by: madao on December 07, 2019, 06:43:20 am
Ramp like resistor and current over 10mA is reached.
Sadly, it is dead.
Tunneldiode doesn't like good long high current about peak current . This is a notice.
Regards
matt
Post by: jonpaul on December 07, 2019, 04:48:27 pm
Hello the TDs are available on epay occasionally new packages or Chinese copies or Russian equivalent
NEVER USE a func gen 50 ohms without a 1 k series resistance
Use a positive only ramp no negative!
Read up on TD precautions and testing first.
Even a microsecond of overload kills them, eg static electricity.
Handle with static precautions
Jon
Post by: GerryR on December 07, 2019, 05:46:44 pm
Here's a quick tutorial by W2AEW:
https://www.youtube.com/watch?v=PuG8CCUbg58 (https://www.youtube.com/watch?v=PuG8CCUbg58)
