Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Tell me about simple batteryt tests please
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tell me about simple batteryt tests please (Read 1215 times)
001
Super Contributor
Country:
on:
September 03, 2018, 07:49:33 am »
Hi
I put 360Ohm resistor and 9V battery in SERIES and read current (25mA is ok)
But someone told me what I must connect resistor in PARALLEL with battery and read VOLTAGE sag
Logged
PhilipPeake
Regular Contributor
Country:
Re: Tell me about simple batteryt tests please
Reply #1 on:
September 03, 2018, 08:19:31 pm »
Either will work, you can calculate one from the other.
In your case, you have 360 ohms across 9v. You see 25mA flowing, so you know the voltage (I*R) must be 9v.
Your load is not causing the voltage to drop, so your battery would appear to be ok.
Logged
DaJMasta
Super Contributor
Country:
Reply #2 on:
September 03, 2018, 08:35:14 pm »
Since your circuit only has a source and a load, completing the circuit will make the load in series or parallel interchangeably, the terms really only apply when there is more than one element in the circuit.
Probably the beginner forum is a better place for this, since it's not about test equipment.
Logged
http://www.medpants.com/
- W3BSN
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
