Products => Test Equipment => Topic started by: Shas-O on July 08, 2013, 07:24:19 am
hi Dave
Did I see that you have a HP 3457?
We just purchased the Agilent 3458, which I think is a later model, and found that the current posts were loose.
This affected readings if the leads were moved.
Seems the fuse holder is built into the post, dumb asses.
Is this the same on the 3457?
Derek
