Author Topic: Yokogawa DL2700  (Read 5572 times)
Offline TektronikTopic starter
Yokogawa DL2700
« on: May 10, 2016, 11:10:46 pm »
Hi :)
Does anyone know something about this oscilloscope ?  :-//
I prepare to buy this model, but I don't know enough about him  :-//
...sorry for my english  :(
« Last Edit: May 10, 2016, 11:29:02 pm by Tektronik »
Offline Hydrawerk
Re: Yokogawa DL2700
« Reply #1 on: May 10, 2016, 11:42:24 pm »
« Last Edit: May 10, 2016, 11:44:41 pm by Hydrawerk »
Offline pascal_sweden
  • Country: no
Re: Yokogawa DL2700
« Reply #2 on: May 11, 2016, 12:23:35 am »
This scope looks very nice!
Would be a cool find in NOS condition :)
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: Yokogawa DL2700
« Reply #3 on: May 11, 2016, 05:18:09 am »
Well, as already stated it came out in 1997, 150MHz bandwidth, was available with 2, 4, 6 or 8 channels and had a sample rate of 500MSa/s (half-channel) and 200MSa/s (all channels). I think 1M memory was standard, with up to 16M as option. There also was an MSO option.
Any reason you want this particular scope? Unless it's really cheap and/or you need more than 4 channels on a small budget I'm not sure I would buy this scope. These scopes were designed pretty much as long-term multi-channel recorders, and the update rate is generally poor (single digit updates/s). And if something breaks, getting spares is pretty much impossible.
« Last Edit: May 11, 2016, 05:23:37 am by Wuerstchenhund »
Offline nctnico
Re: Yokogawa DL2700
« Reply #4 on: May 11, 2016, 06:28:31 am »
I wouldn't rule out getting spares. I bought a DL1740 last year and much to my surprise it was very easy to obtain new custom ASIC front end amplifier chips.
« Last Edit: May 11, 2016, 06:38:47 am by nctnico »
Offline Fungus
Re: Yokogawa DL2700
« Reply #5 on: May 11, 2016, 06:52:45 am »
Any reason you want this particular scope? Unless it's really cheap ...
Let's give it a value: $150 at most (in working condition with all probes, etc.)
The photo appears to be from this eBay auction: http://www.ebay.com/itm/262261015873
At that price? No way. Definitely not.
« Last Edit: May 11, 2016, 07:11:52 am by Fungus »
Re: Yokogawa DL2700
« Reply #6 on: May 11, 2016, 11:11:35 am »
I don't think $150 is realistic, more like $300 to $500 for a working scope in good condition.
I agree, especially when considering this hasn't really been tested, there is a issue with some buttons and that the LCD screen looks very dim.
Offline Muxr
Re: Yokogawa DL2700
« Reply #7 on: May 11, 2016, 06:07:44 pm »
Those are some decent specs for a 1997 digital scope.
Re: Yokogawa DL2700
« Reply #8 on: May 11, 2016, 07:40:43 pm »
Yes, indeed. The sample rate is a bit low, but the large memory and 32bit MSO was quite unique back then. If I remember right it also comes with decent statistics, large memory FFT and history mode.
