Author Topic: Triaxial test cables for HP 4140B pA meter?  (Read 561 times)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« on: May 07, 2019, 07:46:58 am »
I recently got my hands on a HP 4140B pA (pico amp) meter and DC voltage source for a good price. I figured it'd be something fun to play with. :)
It looks like the pA input uses a triaxial connector, of which I have nothing in my stock of parts.
I found this on Digikey, but it's not the cheapest test lead out there (I know triax is expensive...)
https://www.digikey.com/product-detail/en/pomona-electronics/5342/501-1407-ND/737265
Does anyone have any suggestions on what sort of test lead I should even be looking at? Also, does 50ohm/75ohm matter here?
« Last Edit: May 07, 2019, 12:51:08 pm by TERRA Operative »
Any circuit design must contain at least one part which is obsolete, two parts which are unobtainable, and three parts which are still under development.
https://www.youtube.com/user/NearFarMedia/
Online HighVoltage
Re: Triaxial test cables for HP 4140B pA meter?
« Reply #1 on: May 08, 2019, 07:34:56 am »
The keyword to search on the used market is "trompeter" and "triax".
Sometimes you can get lucky to find good cables and connectors for a good price.
The price on Digikey is not too bad.
I have seen much higher prices for name branded cables.
Offline VK5RC
« Reply #2 on: May 08, 2019, 09:39:11 am »
+ search for the term TRB connector, the cable is relatively cheap but the connectors crazy, watch out for 2 (older) and 3 lug versions. If you make your own - remember the impedance needs to be in terraohms - no touch!
  • Country: jp
« Reply #3 on: May 08, 2019, 10:23:50 am »
Cool, thanks for the info, I'll keep having a look around here and there.
I have the 3 lug type on my machine, they seem common enough.
I'll also be sure to not touch stuff, maybe I'll wear gloves if I assemble my own cable. Would a wipe down in 99.9% Isopropyl alcohol be alright if needed?
Offline VK5RC
« Reply #4 on: May 13, 2019, 12:05:42 pm »
I made two  2 to 3 lug adapter cables - to join my Keithley Electrometers  (617 619)  to a HP Test Fixture Set  (16058A).
I used the no touch technique - but had washed my hands in IPA first - and the resistance between the layers of triax was not measurable - so I was happy.
Those are expensive connectors!
Hope it goes well.
Rob
