I am starting to think you purposefully seek old cheap / needy TE just so you can have an excuse to play with your 3D printer to make this or that custom part...
Getting to this point involved moving a dozen or so heavy-ass 1m2 cartons
What do you guys think about a Picoscope USB thing? Do you have one?
I am interested in just how good I can make a button look. Vince - if I can make it look like the original gloss plastic button I'll show you and see if I can get you approval. If I can then, I will have achieved what I once thought was impossible.
today i received a present to myself 🙂 on Dutch ebay 'marktplaats' i bought an Tektronix TDS1001C-EDU 40MHz /500MS/s
turnsout...its brandnew, in an original box with all cd's books 2 100MHz probes original and trim screwdriver... its all there and original.. amazing !
just checked the menu... it says 5 power cycles ))
C version has colorscreen, EDU (for schools) had all this nice software too.. cool
So if one is looking for this EDU software, i can put it online for download.
So if one is looking for this EDU software, i can put it online for download.Nice haul, why has it a another fascia overlay, what is that used for?
You are probably right!
I think I'm going to get me a bottle of glossy black model paint. I have a whole bunch of colors for model railroad painting but that's all flat paint. I have painted PLA plastic but not with gloss paint. I am interested in just how good I can make a button look. Vince - if I can make it look like the original gloss plastic button I'll show you and see if I can get you approval. If I can then, I will have achieved what I once thought was impossible.
OK so the two main things I would try to improve on your knobs, what jumps at me, are :
- White dot is too big, larger diameter than the original. Either too much paint, or you did not measure it accurately enough, or you did but the printer did not manage to do it properly in which case you need to compensate for that by asking it to make a smaller diameter so that once printed it ends up at the appropriate diameter.
- On your first pic the narrow side of the button is clearly undulating like mad, not straight at all. I guess it's inevitable with a 3D printer that melts plastic.... maybe printing the button more slowly would improve it, but you will always get ridges anyway, even if the overall shape is straight, as can be seen on the underside of the button.
Personally, if you are intending to make a better match (already good IMO), I'd only bother with the top 5 to 7 mm as that is the only part of the knob visible, why wast e all that effort on parts that are not normally seem
Wow I didn't think I was seen as being so anal... oh well. I just like to make things as good as possible... within reason. If you can make something noticeably better with a small to moderate investment in time (learning curve / experimentation ) and money (tooling/supplies)... then why not try it...
So... I guess the only way to "clean up" these ridges and undulation is to mill the part on all 4 sides.
I guess you don't have a milling machine but maybe if you have a drill press, you could buy a little milling tool that you can mount like it were a drill bit. That must exist somewhere...
Well you could do it by hand (with the part held in place in a vice at least...) with a rasp. When I did my training in aviation, making custom aluminium parts by hand, with had a special rasp we called "râpe à Dural ". The "teeth" were shaped like circles/arcs, what you would get if you had put the part in a milling machine. It was like milling.. but with a hand tool. So you could easily make an edge or surface perfectly straight and smooth, was great. I don't know how it's called in English....
Top side of the knob being concave, that won't work, so maybe remove imperfections by hand as best you can with a scalpel, or simply with wet sanding at increasingly fine grit, until smooth enough to be painted. Actually since the button is small, you could do it all maybe with sand paper. Like you do when you sharpen wood working tools : you glue the sand paper flat onto a hard & flat surface, like say an old mirror or something. You secure that to your bench, then you work the button faces flat onto that sand paper... You need to try everything see what works best !
Thank you!
yes super lucky.. it did say used and the price i paid was also for used...
That extra overlay is German, i will keep the English
They are excellent. I currenly have 3 on regular use. A 8 bit 20MHz small as portable scope and gamma spectrometer. A 16 bit 2 channel for high resolution work both 'scope and gamma spec. Modtly bench. And then a 4 Channel 16 bit automotive kit.
I also have a few of their older parallel port 'scopes from previous use and some of there data loggers and temperature measurement interfaces.
Support is excellent as is the software. Great serial decoding at no cost too. I highly recommend them. Been using them personally and professionally for over 20 years.
Oh nice!
If there's anything interesting on those CD's, you should upload to the tekwiki.
Thanks for your observations.
Yes, due to the nature of the 3D printed surface it can draw paint away in very tiny "channels". That's all that is. The best way (searching for perfection now) is to:
Sand the button with very fine sandpaper
Prime the button (or part)
Sand again
Prime again
Sand once more
Paint with gloss black
Use toothpick to "dot" the dimple
Quote from: VinceOn your first pic the narrow side of the button is clearly undulating like mad, not straight at all. I guess it's inevitable with a 3D printer that melts plastic.... maybe printing the button more slowly would improve it, but you will always get ridges anyway, even if the overall shape is straight, as can be seen on the underside of the button.
Yes that was caused by trimming with a knife - not the printer.
OK I see... inherent to printing process, crap
You could just put prime/paint the top of the knob to fill the "crevasses" or whatever the white paint had seeped into. Then sand that down to be smooth. Then make a clean dimple using a cutting tool. Secure the knob in a vice, bring it to the drill press. Don't use a regular drill bit as it will probably make a mess. Instead use one of those bits that have a flat end/face, rather than pointy/conical. I don't know how it's called.... we used on aircraft fitting when a fastener was too close to the radius / pocket edge and the head of the fastener would be prevented from sitting perfectly flat on the fitting surface, hence not doing its job properly. We called it "spot face "IIRC in English on the drawings. Google confirms that, here is a random YT example :
Mouarf.... trying to fix a VCR, first one in my life, never worked on these things before...
It was given to me and I thought hell, would be cool to (try to...) fix it as an exercise and to have at least one VCR around, you never know when you might need one... seeing as I tend to like old stuff, who knows, might come handy one day.
Anyway. First it did not power up at all. Was bloody RIFA. Removed it, works fine now. don't have VHS tapes but the old guy who donated the VCR also donated a tape of Star Wars the Phantom Menace.
Anyway it plays the tape... audio is just fine, I can hear the movie sound track just fine, but no video !
I tried using SCART and video composite on two different LCD monitors equipped with these I/O, and every time the same answer : " No sync ", and a black screen, so not happy.
Looked at the schematic, have partial ones, not the main board sadly... but have the one for the rear panel PCB that carries the I/O connectors, and plugs right angle to the mother board.
I see that the video composite signal comes from a chip on this board, and is served to both the RCA jack AND the SCART connector. Apparently SCART has both RGB and composite signals available. I don't know which one the monitors actually use when I ask them to display SCART. Anyway, at least if make some sense that both SCART and composite would not work...
Anyway, I scoped the composite signal on the RCA jack, and to me looks like a I do have my composite signal ?! So why doesn't it work ?!
I know squat about video let's be clear.... I simply looked at Google to find diagrams of what it should look like. I have my negative sync pulse, about 5us as it should. Total frame length is about 64µs as measured with the cursors, which is what it should be about. So as far as sync goes, the LCD monitors should be able to detect a signal eh ?!
My two main worries that might explain the problem (?!), tell me what you think :
- Noise... as you can see from the video clip below and my screenshot, there is lots of noise... but that could just be my probing setup which is more than awful of course, not having a BNC to RCA adapter nor even a coax cable.. so just using my probe in x1 and a little contraption made from recycled RCA jacks. It's too ugly to be showed here, don't want to stoned.
- Looks like there is a HF signal superimposed on everything, whose vertical excursion spans the entire composite signal... looks like faint squiggly lines at the top and bottom of the waveform. This does not show on wave form diagrams I see on the net.. however I understand there are two combined signals on these things, "luminance" and "chrominance", so maybe what looks like squiggly lines is just one of those two signals and everything is fine . I am so clueless it's painful.
- Voltage levels : 99% of the diagrams I found do NOT indicate voltage levels. Instead they use funny "IRE" units, whatever that means, to give the proportions of the various parts of the signal, but not actual voltages. Proportions look fine on my signal, I find. Video content is about 2+ as high as the sync pulse.
The rare diagrams I found that did indicate voltage levels, showed a 1Vpp excursion, but I get as you can see 2.5Vpp or so !
It's so horrible to hear the sound track of Star Wars but not being able to see the video even though I can see it on the scope !!!
Anyone here with working knowledge of composite signals ? I am in Frog land so I guess we are talking SECAM, though from what I see, SECAM / PAL / NTSC have very similar looking wave forms...
Oh nice!
Jarid.. 'The Tekwiki' ?? for a none tekboy (for now) .. i google like 20 tekwiki's ?
