Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 20255803 times)
0 Members and 28 Guests are viewing this topic.
« Reply #12300 on: June 22, 2018, 10:13:00 pm »
@Specmaster... Yeah similar. I've put all the hungry stuff and the PC on the block connected straight to the wall. Even with everything full whack it'll only pull 750W across the bench which isn't a lot.
@Tautech... good point.
@Cerebus... they're about £7k a seat when new and worth entirely a crate of beer or £20 when someone wants to get rid of one ;)
« Reply #12301 on: June 22, 2018, 10:14:01 pm »
Gee whiz....
Very punny.
 :-DD I was wondering if someone would pick up on that. I guess our British friends didn't because of the language barrier. American English vs English English  ;D
« Reply #12302 on: June 22, 2018, 10:14:57 pm »
I'm ashamed I didn't notice that  :-DD
Going for a whiz up the side of the pub on the way out was a regular occurrence here.
« Reply #12303 on: June 22, 2018, 10:15:15 pm »
They had benches similar to those at the Phillips Lab in Cambridge auction, I wonder what they went for in the end? There's no way on earth that they are actually worth 7K each really, its the fact there's not much competition in the lab market I guess. All it is really is some metal sections cut and welded, a bench top and some trunking with sockets, couple of lights directly mounted onto the metal sections.
« Last Edit: June 22, 2018, 10:20:19 pm by Specmaster »
« Reply #12304 on: June 22, 2018, 10:16:13 pm »
Close to the starting price. Difficult to shift and if you really need one you're usually in the financial situation to be able to afford a new one.
« Reply #12305 on: June 22, 2018, 10:18:10 pm »
Same on this side of the pond. Auction houses have them for pennies on the dollar in lots of two to four at a time. If only I had the space.
« Reply #12306 on: June 22, 2018, 10:20:06 pm »
Gee whiz....
Very punny.
Yeah, it was puntastic.
That's OK. Perhaps you need to puntificate on it a bit.
« Reply #12307 on: June 22, 2018, 10:24:39 pm »
I'm in the garage tomorrow looking some angle brackets so I can fix my function generator and LCR meter to underside of my shelf. I'd like to mount the TF930 up there too but I'm worried about spoiling the resale value of it later if I upgrade it.
I suppose I could pop into B&Q and buy some aluminium strip and make some brackets to sit under it and suspended it from the shelf and maybe even the TGP110 as well, then I put the SG63A in their place and the top of the PM3390B free to the air for improved cooling effect  :-+
« Last Edit: June 22, 2018, 10:30:03 pm by Specmaster »
« Reply #12308 on: June 22, 2018, 10:28:28 pm »
Looks like I've started a trend. You must post pix  :-+
« Reply #12309 on: June 22, 2018, 10:31:01 pm »
Yeah, I will once done  :-+
« Reply #12310 on: June 22, 2018, 10:32:44 pm »
Gee whiz....
Very punny.
OK, lets all go piss on the concrete column just like Roger Daltrey and Pete Townsend.  :P :P :P :-DD
« Reply #12311 on: June 22, 2018, 10:47:07 pm »
And here I thought I had gone too far. :-DD
« Reply #12312 on: June 22, 2018, 10:56:08 pm »
Nah, fraid not, this is the sort of off the cuff banter that makes this group the place to be, fairly relaxed atmosphere and generally if people can be bothered to read back a couple of postings will see that it is all  related to general TEA talk anyway.
« Reply #12313 on: June 23, 2018, 03:57:52 am »
Yep. Another round of TEA for everyone! :popcorn:
« Reply #12314 on: June 23, 2018, 04:42:47 am »
Gee whiz....
Very punny.
No, you want to pee when you're at apogee... then you can have yourself an 0-Gee whizz!
*Ducks soggy ol' boots thrown from multiple directions*
"Thank you, thank you... I'll be here all week..."
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #12315 on: June 23, 2018, 05:20:03 am »
Testing Coils for inductance..
that old LARU is perfect, 0,1µH to 1H. The power cord was rotten, the instrument self typical Rohde+Schwarz of the 60s, still allready working.
It is a resonance tester.
For comparement i used the Tek 130, the test coil is a 270µH
130 is not a resonance tester.
« Last Edit: June 23, 2018, 05:22:23 am by Martin.M »
« Reply #12316 on: June 23, 2018, 07:24:01 am »
Tek 130 is an interesting and very nice bit of kit. I built half a clone of one of them (must finish that) using slightly more modern tech. It uses a fixed and variable oscillator and measures the frequency difference by mixing, passing the sum product through a filter and then counting pulses. When you zero it rather than adjusting a bridge you’re synchronising the oscillators to zero beat.
« Reply #12317 on: June 23, 2018, 01:24:17 pm »
Our weekend ebay fraudster is back, this time as bigmike13 and using a slightly different off-ebay payment route, but with the same items and photos as before.
When, if ever, will ebay get their act together to automatically alert themselves to this style of listing? If I can spot it every time, why can't they?
« Reply #12318 on: June 23, 2018, 01:47:43 pm »
Yeah I've seen and reported that already. Tossers! Doesn't require a lot of clue from ebay.
Decided to shift some stuff today to make room for more toys, including the 465. At least there's an honest seller out there ;)
Edit: also bought another QRP labs QCX and enclosure. Woot.
« Last Edit: June 23, 2018, 01:51:31 pm by bd139 »
« Reply #12319 on: June 23, 2018, 02:33:10 pm »
And another, that bastard needs catching, instead of ripping people off, get a real job and be proud that you worked for your living[emoji48]
From mobile device so predictive text might have struck again [emoji83]
« Reply #12320 on: June 23, 2018, 03:21:39 pm »
You're selling one of your 465's? Too bad you aren't on this side of the pond. Planning on making any trips to NYC for your programming bid? If yes, I'm about 75 miles north of NYC and barring traffic I could be at JFK in under 2 hours.  ;D
« Reply #12321 on: June 23, 2018, 03:25:05 pm »
Indeed I am. I’ve nursed it back to health and it needs to move on.
Unfortunately not heading out there any time soon. Wouldn’t mind a trip out there however :)
« Reply #12322 on: June 23, 2018, 03:47:17 pm »
Oh well...it was one of those quick brain farts.  :-//
« Reply #12323 on: June 23, 2018, 05:20:15 pm »
Fucking eBay dicks. Just had this via direct email not via eBay for Tek 465.  Not sure how they got my email but it was from eBay as I have a dedicated alias for that.
Lagos. Seriously. Get fucked
Hello,
My cousin in Lagos, NIG. love it.
I will pay for it plus £25 for shipping via post office Royal Mail International Standard Signed For:.
Please reply if it is OK by you for payment by PayPal.
Thanks
« Reply #12324 on: June 23, 2018, 05:28:14 pm »
You have a long lost cousin in Nigeria?  Do they have access to all that lost cash they find in banks there?  :-DD :-DD
