WELCOME TO 5000! -group-therapy-thread/?action=dlattach;attach=1059122;image)
I think this is probably a good point to call it a night.
Hi Dwagon, Did you see my posts
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg4275517/#msg4275517
and
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg4275556/#msg4275556
Looks like same video scheme as the 892x series a Gondbes 8220 video converter would be my next stop.
Yup, sure did; and followed that rabbit-hole down to that LCD mod. Very tidy!
Problem is that the models we have tech ref on... the ones we've been talking about... are all proper non-greyscale monochrome monitors. Also, this family of monitors are all "1000 line" resolution (IIRC, I read that they "use" ~960 lines), so not too sanguine aboot dropping down to 800x600 resolution.
There's a CDM-7SX191 monitor on eBay right now for $80... I've been meaning to get into one of these Chinesium video scan converters as a diag tool for a while, so that might still happen... but I think that if I were going to fix this scope, I'd prolly bite the bullet and buy that monitor.
This of course is all dependent on how my dispute resolves out.
I wanted to spend a little time tinkering just to see if there were signs of life; I was hoping it might be easy to mod the CDM-7SF191 I have in that 54600A so it thinks it's a CDM-7SX191.
I may instead try remoting into it over the RS-232 instead... in which case I'll soon be hunting down that software you posted and firing up the old WinXP Toughbook.
More CRT types needed.
54600A Pixel_data and Marker_dots are already 32 levels internally, but only 2nd and 4th of Pixel_data are used externally.
So taking out all five is pretty simple but the situation should also be very clearly visible in the monitor.
Old Intensity reference pot can grant its pins.
54600A Pixel_data goes through U37 74LS194 and then HB goes to U30 74ALS08, FB does the same but first ORing Marker_dots in U31 74F32, so either will do a final FB.
All gates are used so extra chip must be added, no idea when the device is designed but 5 TTL monitor pins feels a bit too much.
nixiefreqq's neck board has 1 FET and 3 BJTs, I'd say that 5 TTL pins are not there.
Since 74S03 is the earlier model my guess is that later monitors became better and external data level reference was not needed anymore.
So comparing two datalines will tell how the situation is.
Testing with an extra *old* computer monitor should also be pretty easy, if one is available.
One gate chip is needed, old display modes were selected by swapping sync polarities.
Using only green as data is also fine.
Functional monitor is not needed if vertical line movement is possible, since its color value is different it should be very visible.
Maybe duplicating buttons of two side by side machines can do settings.
Resolution
255 V x 500 H 54600B
256 V x 500 H 54615B
54620-series
255 vertical by 1000 horizontal points (waveform area)
32 levels of gray scale
Is it really 1000 pixels?
Vertical is the same as before so monitor is probably also pretty same as before.
I tried to find some tube info but everything was too old.
So no real idea of physical resolution of those 7" mono tubes.
But it can be checked, just compare those old and new 546xx horizontal lines, 1000 res has half the pixel length.
If shorter pixel length is there then different CRT must be also present, if that is the key.
It is entirely possible I misremembered the line count on this monitor and conflated the numbers with those above. We know that the 54645A is using a PAL combi chip, so up to 625 lines (I can't remember if that's interlaced or not) to play with; so yeah, I can see those numbers being legit.
54645A and 54600A both use the same DataRay CDM-7SF191 part number. I've attached some pics. The main and CRT PCBs appear identical, even though the older CDM-7SF191 in my 54600A uses a Panasonic M18JCB34GH CRT vs the Toshiba E9054B31-CDHT CRT in my 54645A. That Toshiba CRT, however, is the same as the in the 54621D, so the CRTs in all 3 models must be interchangeable?
I'm thinking now that my original surmise is correct... provided nothing wrong with the mainboard, we should be able to get something useful on the screen with the 54621D and the CDM-7SF191 from my 54600A. Just need to see how they're modulating the brightness to get those greyscales. I guess my next step will be a breakout PCB.
For now, tho, I've had to put it away; wifey has requested I look at the AC in our old Saturn.
Yes, CRTs are definitely interchangeable.
So monitor hack, shouldn't be overly difficult.
Old Hitachi/Matsushita schematics is too old and something seems to be missing but those two neck boards are very same.
Older neck board uses 74S03 as parallel inverters powering contrast trimmer directly and newer one seems to be different only from there.
Oldest has no neck board but contrast pot connection is pretty exactly same as 74S03 version of neck board.
Are all those 54620-series machines already closed.
More revealing solder side picture of neck board would be nice.
Completely forgot 54645A/D, its resolution was clear.
313 V x 512 H (pixels)
That's clearly PAL, but proportional and lowres.
Is there visible space between H-lines?
Back in the day CGA was clearly using only every other line of available physical pixels.
From pictures online there could be something missing but it is not much, dimming can reveal something but it doesn't change anything.
Full hires for PAL is 31250Hz H-sync, 31500Hz for NTSC.
Old Hitachi/Matsushita schematics has 24270Hz as H-sync and 60Hz as V-sync so 404 lines possible.
PAL and NTSC were also defined as 720 pixels wide, but no idea how much was physically available, not much more I guess.
One thing I remember though, very small pictures were exceptionally sharp.
So more than 500 was a norm already back then but no idea what was the major barrier, screen material or cathode ray energy.
FET in newer neck board indicates that rising time had a role.
From online pictures I'd say that 54600B grid is 100x60 pixels, vertical center line is around 128.
Vertical 256 must be a grid area, horizontal 500 seems to be all.
54622D pictures were pretty bad but horizontal pixel count seems to be more than those 54600Bs.
How this all then should be converted to VGA or SVGA.
Anti-aliasing is difficult when contrast is high and lines narrow.
One other thing, PAL pixel is not round, for that it needs a 5:4 screen, but that is for 576 visible scanlines.
Very nice, and clear.
What is the shape of the screen here?
Online pictures are pretty hopeless.
