All it takes is one fucker with a hedge trimmer to ruin your day. Doesn't matter where you live.
Not with a 250MB/s P-P wireless connection and your ISP's UPS in the house keeping your connection up !
The Pop part of Mom& Pop was here today for a coffee and checked our connection speed ....as just reported and also dropped off a new 3 blade 24V wind gen to go up the hill on our backhaul site as this winter the PV panels have struggled to keep the batteries full which has pissed us off some needing to keep an eye on the bloody things every time we have a session of dull weather......then a few days back it became obvious why, apparently at high altitudes the southern hemisphere still has a lot of fine ash aloft from the big Tonga eruption a few months back.
Anyways, one of these suckers:
http://www.primuswindpower.com/wind-power-products/air-30-turbine-2/
Wonder how long it will last 200m ABSL where there are unrestricted views between Aussie and Chile....translation = blows like a real SOB !
Pics to follow when installed.
In that case, all it takes is a stray cow to scratch it's ass on the pole
The wind gen site is already up and running with an 8' galv pipe mast bolted to one of the posts on the post and rail around the control cabinet and 6M timber pole but with a vertical helical POS generator that's only good for landfill !
That helical thing has been a real disappointment so it must go and be replaced with something designed in the US of A that might actually work !
And so over the last couple of days it was done.
Yesterday (Monday) in readiness for the real installation work, the useless helical turbine, its 3 phase controller and wiring was removed and new 2 core tinned marine wiring installed and ~600mm extension to the 1.5" galv pipe mast so to make today's efforts simpler. The weather was closing in and we did most of this in light rain but with barely a breeze, thank heavens !
This thing:
Air X Marine wind turbine with 110mph survivability....and it will need it !
http://www.primuswindpower.com/files/7816/0709/3270/PWP_Manual_-_NOV_2020_-_3-CMLT-2020.pdfThe 3 carbon fiber blades are as sharp as one thing hence the need to add an extension to the pole to prevent it from scalping us anytime we needed to work on any part of the installation.
Now blowing 20+kph tonight and already we can see the batteries benefitting from charging after the sun has long gone.
Pop of the Mom&Pop ISP is well pleased as we can both see 25.16V at the batteries from the solar logging whereas just after dark 3hrs back it was 24.42V.
In a few days I'll grab a screenshot of the latest logging which should clearly demonstrate the challenges we've had with keeping this installation fully charged this winter.
Anyways, you've probably seen pics in previous postings so I won't bore you with old ones, just one of the new turbine and a bonus one of the indicator LED's on the radio of the 900mm 11 GHz dish with 900W of solar panels in the background.
Next upgrade is to the DC powered POE 1GB/s switch, of which the current 6 port one is full so no spare ports for local management without unplugging something and a local POE camera is planned to be added.
