...You have entirely too much "free" time on your hands. I think you should drag out one or two of your
scopes and revisit them... maybe post some hollow-state pr0n in the thread.
I will get back to my regular boat anchor activities as soon as schedule permits. Maybe in 3 months. For now, need to finish sorting and organizing my components and misc H/W, almost done. Then I need to resume work on my Rochar Nixie DVM because it's in a millions bits all over the bench so I need to finish it, assuming I am competent enough to actually managed that, while it's still fresh in my mind, and before I lose parts and/or forget how to put them back together...
But if I can get those first few things I listed, done this year, that would be cool.
Ahhh, I had forgotten that you did in fact already have a smallish
on your bench. So what specifically is the holdup on that; I know funds are short?
Not a money problem. It's just that it's a very sick puppy with numerous intertwined random problems, that drive me nuts. So after battling very hard, I managed to make progress, but there is still much to be done, and it was always on step forward one step back... eventually reached mental exhaustion and needed a break, I had no juice left for this thing. So I put it aside and switched to other things, then one thing led to another, and soon the Nixie DVM moved down the priority list. As the saying goes : " Life got in the way " !
So let me see... searched TEA a bit and found that my lat post / work on it was exactly 3 months ago. Since then :
- Acquired that rack mount Tek type 317 hollow state scope, so worked on that. Still need to finish it up by replacing some electrolytic caps.
- Worked on my HP 120B hollow state scope, CRT glass / neck got broken and HV winding in the main transformer is arcing badly, no HV anymore.
- Embarked in identifying and sorting all my components, what an adventure.
- Fridge thermostat needed replacement, so had to design and build an electronic replacement / timer, while trying to fit that "universal" thermostat my dad sent to me, which didn't quite cut it. Looks like the contact in it is seized closed, compressor runs all the time. So need to buy the proper replacement. But since my electronic timer works just fine, it's running off of it for now. Been a couple months now maybe... runs like a charm. I have now patented it and shall soon start mass producing it for the low low price of 250 Euros a pop. Need to pay for the construction materials for my garage somehow, you see, and their prices have exploded. Not that they were cheap to begin with either.
Then the handle that keeps the small freezer compartment shut, inside the fridge at the top... broke. So now I can't use it anymore, bummer
- Dad finally, after 3 months, got done manufacturing custom plinths for my bedroom, and delivered them to me. So I then had that on my plate. Was a chore cutting them into bits as accurately as possible with the miter saw, then gluing them in place, then a bead of white acrylic to make it perfect and fill all the small gaps with the wall and at every joint between two plinth pieces. Now need to put two coats of paint but.... it's so fucking hot here with that heatwave, that even at 3AM it's still too hot to do any painting unless you are completely out of your mind.
So I am waiting for the weather to cool down a bit, if it ever does in the coming days, so I can paint that.
- Friend gave me that stereo all-in-one shit box to fix, you must remember that, you helped with it... that cheap CPU that keeps the USB and SD card reader from working...
- Then I fixed that Matra aerospace 3 phase 400Hz 115V inverter
- And the other day I was given to fix that huge 55" smart TV to fix, backlight problem. But the LEDs keep blowing like there is no tomorrow, so I told the guy sorry it's scrap. But then I searched a bit and found out that this TV is still sold today and costs a freaking 1650 Euros, which pre-war would be about 2,000 US dollars. So I thought OK let's make an effort to save that fucking TV. Found new LED strips for that very TV for 45 Euros on French Amazon. Then found the same on Aliexpress for 14 Euros delivered... guy gave the green flag to buy that, accepting the fact that it might be wasted money if after reassembling everything we discover that the LCD got damaged during disassembly / storage / reassembly. He was fine with that. So, I am waiting for these strips to arrive from China. Maybe in 10 days if I am lucky, in a couple months if not so lucky. We shall see.
I may have forgotten a thing or two but you get the idea : I got busy doing other things, and time flies ! I can't believe I stopped working on my meter 3 months ago already ! Needed a break, for sure, but now it's about time to get back to it I think !!!
