TEK 7603 PSU RECAPFIXED !
No connectors were to blame. I had made a mistake when soldering the replacement caps for that -15V rail.
Old can had of course 4 negative pins, and the circuit board relied on that, it used the can as a jumper to complete the circuit. So basically the cap was not even connected to the connector that sends that -15V to the regulator board.
Of course I knew this could be an issue when I started recapping this PSU, but I got caught anyway. I did pay attention to that, concerning another can, because it was screaming at me : its 4 pins/pads were not connected to anything, none of them ! So of course that caught my attention and I looked underneath the board wit a torch light to study the traces and figure out what I need to do exactly to get it to work. Ended up adding two jumper wires.
Anyway, so I soldered a jumper wire to complete the circuit of that faulty rail, and the scope now works, yeah... however I am still NOT happy !
.. because it has not solved my issues ! The display is still as crap as it was before recapping the PSU !
Fat fuzzy trace and readout, readout that "wobbles" like a jack in the wind, and very noisy signal trace. The flat line It looks like it were a pipe with little balls rippling inside it, so to speak.
Well I guess recapping this old scope was a good thing in the long term anyway, and I can now rule out the PSU, so I am making progress towards a diagnosis I guess.
So if the PSU is not to blame, I guess it's the CRT circuitry itself that's to blame ? I am out of my comfort zone here.
Maybe there are some crapacitors in there as well, that cause the noise / fuzziness and wobbling ?
Need to look at the schematic to see if there are electrolytic caps in there.
A piece od good news though, regarding the time base plugin. I have two of them, same model, and I could not get the dual time base to work. So I RTFM and experimented a bit, I got the hang of it now. It's not defective, it's just that I had too high an expectation : I assumed a dual time base could display both the main and second time base at the same time.... but this scope can't. You can only display one or the other, but never both on the screen at the same time.
However there is still something I can't figure out : how to tell the scope to trigger on a rising or falling edge ? Only button I see related to that, is located on the time base plug-in, but it has no effect : the scope triggers invariably on the falling edge, no matter the position of that button.
Looking more closely, looks like it might be normal : that trigger edge button looks like it's meant to acts on the plugin's external trigger input... not the signals that you apply to the vertical plugins.
So, how the f*** do you select rising or falling edge ?!
I can believe that such a fancy state of the art expensive scope, that it was at the time..... can't even let yo select the trigger edge....
Oh, and the graticule illumination is piss poor as well. I guess the incandescent bulbs in there are very tired to say the least.
Oh, and the CRT itself looks very tired... with the time base at full speed you can barely distinguish the trace when using a single channel. Press the x10 sweep magnification, or just enable 2 or 3 or 4 channels, and the trace disappears completely... meaning the scope is useless. No point offering specs and features if you can't make use of them in practice
So either the CRT is very tired, or this scope was never that good to begin with ? Trouble is, that's my first 7000 series scope, so I can't compare... I can only judge it compared to other old analog scopes.
Anyway, that's why I just love my 2467B so much. It's a technical marvel. Even with all 4 traces on the screen, sweep speed to the max, x10 mag added, the CRT still has plenty of brightness under the hood to make you blind in broad day light. One needs to see it to believe it. I saw it, so now I believe it. Long live science and engineering, a winning duo
So, the 7603 is basicallt recapped and working again, so I could button it up for now, and work on the remaining issues god knows when. Later.
Will have a quick go at the CRT section tomorrow, in case I can find some low hanging fruits in the schematics...
To begin with, I could put some contact cleaner in the brightness and focus pot, they are really begging for it. Hoping they are not of the sealed type, as I do'nt feel like drilling a hole into theiy body to get the cleaner in there. With my luck I would damage the pots and make things worse...
