It's not a prototype, it's the original late 1960s design.
They had to shuffle the innards about, when the 10544 series oven oscillator became available in the 1970s. They clearly took the opportunity to redesign the two function control boards, into one multilayer board and eliminated the square connector.
They are many other changes, hence the reference to a different manual for the older ones, I need to find the older one.
-group-therapy-thread/?action=dlattach;attach=1738901)
I'll try and get some better pictures of the square connector when I get a chance, they can have boards sandwiched together, or boards at right angles and the fourth side can be either soldered to a board, or have solder points for wiring.
I'm sure there is a nice write-up in one of the HP journals, just haven't come across it yet, if it exists.
They are used in the 5326/7 counters, 8640B signal gen for the counter (again), the 5321 k21-lock.
The second HP 5327B counter (originally missing DVM control board) worked when I received it, but quickly stopped counting while I was checking the counter functions, this again turned out to be an easy repair, which was narrowed down to the function control board, took me ages to find the appropriate extender, then I noticed one of the ICs in sockets looked a bit loose & the pins a little bent, I took it out straightened the pins & refitted it, I also reseated the other two socketed ICs, this cured the no count fault.
-group-therapy-thread/?action=dlattach;attach=1738913)
The next problem was failed blanking on the second number readout bulb, the 7 was lit when it should be blanked, I took the set of decade counter, latch & display decoder ICs out and fitted sockets for my new 1820-0092, 1820-0116* & 1820-0119 boards, this fixed it, I run out of time to confirm if the original display decoder was to blame.
But this did allow me to test the new boards in the higher speed position, they all seem good.
-group-therapy-thread/?action=dlattach;attach=1738919)
*Note: the new 1820-0116 board does not have the gated (recorder) outputs yet, I found this shown in the 8443A manual, something to add to rev.B.
One of the new 1820-0413 boards was tested in the timebase board too, this was required to make sure the gated output was working, the new DVM control board also works fine.
-group-therapy-thread/?action=dlattach;attach=1738925)
Last thing to test/repair, are the 500MHz inputs of both 5327B counters, need to find/buy the top & bottom covers to complete the second 5327B too.
-group-therapy-thread/?action=dlattach;attach=1738907)
